Positive or Negative Ground
   / Positive or Negative Ground #1
GWheat
Member
This Ford 4000 was converted to 12v at some point in time. The main issue is I don’t know how to tell whether it’s a positive or negative ground. Here’s a couple of photos I got this morning before the rain set in.
Any tips or ideas are appreciated.
Thanks
Good old 4 cylinder. Currently has a alternator on it. It’s wired, but that’s one of the issues that’s with the tractor. Or so I was told.
   / Positive or Negative Ground #4
All but certain to be negative ground. There’s few alternators in the world set up for 12V positive ground and no good reason to use one on that tractor.
   / Positive or Negative Ground #5
If you have an alternator, presumeably you don't have a seperate voltage regulator so, one less thing to consider for voltage and/or polarity.
   / Positive or Negative Ground #6
You could bump the starter with a positive jumper cable and see if the fan goes the right way.
Starters are not polarity sensitive.
   / Positive or Negative Ground #7
Edited, so as not to give bad information.
   / Positive or Negative Ground #9
I may stand corrected. BUT, I have never seen a brushed DC motor that would not go backwards with reversed polarity. It does make sense though. You change the rotor polarity and the stator as well, so end up the same. So, every motor I have played with has likely had a permanent magnet for the stator???
Here’s a picture of the alternator fellas. Not the greatest picture. Raining and bit cold today. IMG_1933.jpg
Name on the bottom is Delco Remy
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A49461)
1993 Ingersoll...
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
27 Challenger Boat (A50324)
27 Challenger Boat...
2007 Volvo VNL Truck Tractor (A52128)
2007 Volvo VNL...
2012 PETERBILT 386 (A50854)
2012 PETERBILT 386...
