What is an acceptable gap between the mount plate and the quick tach?
The wrench in the photograph is a 3/4 inch craftsman and there is extra room above it. So, almost 1/2 inch gap. The photograph is looking up into the slot where the pin would be when the two components are mounted.
Right, the reason it is not touching is because it is in the wrong place. It is too close to the top angle. The latch plate should fit down flat where the wrench is, but it is hitting the angle that is in the wrong place:------------------------------------------------------------
The weld in your pic is on the bottom of the plate and don't even appear to be touching in the pic with the wrench.
What I mentioned is another possibility that I ran into myself. Maybe the drawing below helps. There was a bead of weld inside the top flange that prevented the "paddle" from seating all the way up. Removing a small part of the paddle provided the needed clearance. The paddle profile remains unchanged and it works fine.
Of course it could be the plate is just too short.
Definitely a bead of weld in the way. Approximately 1/2 inch wide. I attached the photograph again, the bead is clearly visible.
Also, I emailed the ebay seller and asked if this was his standard and he said it was. He has sold about 100 of these plates in the past year.
The weld bead is not the problem, it is in the wrong place that is causing the problem.
The plate is definitely too short.
Did the seller offer 30 day or 60 day free return shipping?
PayPal will cover up to $30 of return shipping.
