Boom Pole reach
/ Boom Pole reach #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
How much reach does the typical boom pole give you, past the rear tires?
Looks as though the best price is one from Agri Supply: $114 for a 500-1000# lift.
Ralph
/ Boom Pole reach #2
Depends on the length of the boom.
We had a home built one years ago and I would say it was about six or seven feet behind the wheels. Obviously, at full height, you loose reach.
/ Boom Pole reach #3
Ralph
Looks like it is 84" long. Wonder if that is from the pins? If so you could measure how far your tires are behind the pins and subtract.
Heavy duty boom pole
Weight capacity on front loop: 1,000 lbs.
Weight capacity on end loop: 500 lbs.
Attaches to a 3 point hitch
Length: 84"
/ Boom Pole reach #4
Amazing you lose half the capacity of the lift just a few inches forward.
/ Boom Pole reach #5
Ralph
I’ve had a cheap one pretzel on me. I’ve got a better one now. I did overload the little guy...
John Deere MX6 Bush Hog (A64047)
John Deere MX6...
GENIE AWP-36S MAN LIFT (A63569)
GENIE AWP-36S MAN...
2021 Cam-Am HD8 (A64047)
2021 Cam-Am HD8...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2005 FRAC TANK 500BBL WHEELED (A63569)
2005 FRAC TANK...
