Diesel engine oil only ?
   / Diesel engine oil only ? #1
JerseyRay
NW NJ
My New Holland TC33D has a diesel engine. When changing the engine oil do I have to put in a specific oil for diesels or is it ok to use an regular oil that I put in my gas engine car like a Quaker State or Pennzoil? The owner's manual does not specify. It just says it should be 10w-30 oil for all year round.
   / Diesel engine oil only ? #2
Use rotella 15w40 or even 5w40. Synthetic is about $20 a gal at homedepot.
   / Diesel engine oil only ? #3
At a minimum I would think that you should be using an oil with a CJ-4 rating;
CJ-4 replaced the following ratings and it has been replaced its self by the CK-4 rated oils.
CJ-4 oils exceed the performance criteria of API CI-4 with CI-4 PLUS, CI-4, CH-4, CG-4 and CF-4 and can effectively lubricate engines calling for those API Service Categories.
   / Diesel engine oil only ? #4
Yes, and the owner's manual should specify a type that starts with C as LouNY posted.
API Engine Oil Service Category: API Engine Oil Lubricant Specifications - oilspecifications.org
   / Diesel engine oil only ? #5
As mentioned, you need a high detergent oil with a diesel rating (CJ I think is the latest)
Rotella T6 oil will work for gasoline and diesel engines. I use the 5W-40 Rotella T6 in everything, Evinrude 4cycle boat engine, Honda Goldwing motorcycle, cars, truck, motorhome and of course my tractors.
The 5W-40 is good for all season where I live, you may need a 0W-xx for your seasonal weather to make for easier starting in the winter. Consult the charts in your OEM manual for temperatures high and low to determine the correct oil.
   / Diesel engine oil only ? #6
Large investment piece of machinery designed to outlive you. Sure, just throw car oil in. Heck just throw used car oil in, I'm sure it'll be fine:confused:
Is this a money issue or something else that makes you want to use something else?
   / Diesel engine oil only ? #8
When I got my first diesel tractor back before the Internet, I didn't know there was different oil for diesels. :eek:
   / Diesel engine oil only ? #9
Your manual should give you the "C" rating along with the viscosity.
   / Diesel engine oil only ? #10
No you should not use any oil that isn't formulated for diesel engines, if you care for the life of your engine.
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
Drill Bit attachment (A50322)
Drill Bit...
Aer Way Tillage Tool (A50514)
Aer Way Tillage...
2024 RP-12-72W 72in Hydraulic Power Rake (A49462)
2024 RP-12-72W...
