B2410 won't start
/ B2410 won't start #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
After using for some light work, just left the B2410 idling a few minutes. Then she let out a puff of black smoke, died, and won't restart.
I tried bleeding the fuel lines, new diesel, pumping fuel up through the lines, no oil in water and no water in oil. Any ideas would be appreciated.
/ B2410 won't start #2
Could something like a safety switch activated the shutdown solenoid?
Wire fell off the solenoid?
Maybe remove the solenoid and see if it will start?
It does crank over,right?
Good Luck!
/ B2410 won't start
Cranks over good. I'll try bypassing the seat safety switch; that's the one you're referring to, right?
/ B2410 won't start #4
If it was a safety switch, it wouldn't do anything but light up the dash lamps. The starter would not do anything.
/ B2410 won't start
Thanks Bubba. You just saved me a trip out in the rain to check on the safety switch. Now, on with the search :-(
/ B2410 won't start #6
The sh-off sol. is usually mounted to the back of the injection pump. Just remove it.. its usually 2 bolts.
Look to see how it works & "bench test" it.. depending on HOW MANY wires u have, there are diff. ways to test.
2 wires is simply 12v + to red & - to black.
U could/can reach inside the hole & push/pull on the gov. linkage, just like the sol. would when its working.. & see/feel if anything is stuck.
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
2015 Kia Sedona Van (A61569)
2015 Kia Sedona...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A61165)
2016 Hino 195h...
6ft Bush Hog Rotary Cutter (A61166)
6ft Bush Hog...
UNUSED CFG INDUSTRIAL QK16R MINI EXCAVATOR (A62130)
UNUSED CFG...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
