Easiest way to change hitch ball sizes
   / Easiest way to change hitch ball sizes #1
dgeesaman
Harrisburg, PA
New Holland TC45DA
I have a TC45 w 2-5/16 hitch on my drawbar.
I want to also be able to pull my splitter which has a smaller ball. I need an inexpensive way to switch hitch balls back and forth that preferably does not involve busting the hitch ball nut with an impact every time.
Thanks,
David
   / Easiest way to change hitch ball sizes #2
Thanks,
David
I did something like this.
Only to to used around the woods or yard.. NOT HIGHWAY...
I'm going to get scolded how unsafe it is but works for me..
   / Easiest way to change hitch ball sizes #5
I'd figure out how to pin a triple ball hitch to your drawbar. Maybe get one of theses and add a hole on the two axis to match your drawbar holes.
   / Easiest way to change hitch ball sizes #6
I had a similar type of hitch I welded a short receiver tube to the bar stock to enable using different hitches.
   / Easiest way to change hitch ball sizes #7
Get a hitch receiver frame for your 3-point hitch. It is loads easier to use than dealing with the fixed drawbar and has a standard receiver tube that you can use to swap out draw bars or rotate a 3-ball setup. Once you get used to hitching up this way (back up to trailer and lift the 3-pt from your seat) you’ll never go back to the old way.
   / Easiest way to change hitch ball sizes #8
You're not supposed to pull trailers from the 3pt hitch. You're supposed to pull trailers from the drawbar. Yeah, I know most people don't and never have a problem. Just sayin.
   / Easiest way to change hitch ball sizes #9
^^ I had to go that route. The trailer ball mount was far too low and there was no way to raise it or add a receiver hitch without getting in the way of the PTO and other things. I tried several different ways and nothing worked.
I don't try to pull big trailers though, just the splitter and a small utility trailer.
   / Easiest way to change hitch ball sizes #10
The OP is interested in pulling a woodsplitter,, not a Fruehauf 53 foot reefer full of ribeyes ,,,
Heck, he could almost hold the hitch in his hands to move the splitter,, the 3 point should be fine,,,
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500 4x4...
Utility Trailer (A52377)
Utility Trailer...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
Year: 2014 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 59,333 Plate: Body Type: 4 (A56859)
Year: 2014 Make...
2008 Ford F-550 4x4 Rugby Mason Dump Truck (A55852)
2008 Ford F-550...
