Bucket Tilt Restrictor
/ Bucket Tilt Restrictor #1
NCMau
Gold Member
NC
MF 202/Ford 8N
MF 202. I need to slowdown the bucket tilt. From what I read, I can use a restrictor (maybe .030) in line with the cylinders. Could I just place a washer with the proper orifice in the female part of a swivel adapter? It seems like it would be the least expensive to get four of these adapters. I just wander if it is doable without any welding.
/ Bucket Tilt Restrictor #2
Yes you can put an orifice washer under fittings.
Thanks! Now the next question is what is a practical way to make a fitting washer?
/ Bucket Tilt Restrictor #4
The orifice fittings that look like a plumbing nipple (double male) are under $5. Hard to beat that......unless you make your own bolts and nails too!
/ Bucket Tilt Restrictor #6
A restrictor is gonna slow the flow in BOTH directions.
And no need for 4. Put one at the valve and only one.
I'd go adjustable too. That way you can get the exact speed you want without the trial and error or restrictors.
If you don't want to slow both directions, get one that has the check valve and is free flowing in one direction....and metered in the other direction
/ Bucket Tilt Restrictor #7
^^agree^^ If you install a .030" restrictor on each side of a cylinder, only the rodless end restrictor will be doing the restricting. The reason being, for any movement of the cylinder piston, the rodless end is going through more oil than the rod end. So, being that each end of the cylinder operates with a different volume of oil, swapping the restrictor to the other side of the cylinder will alter the restricted speed.
LD1, I like the idea of the adjustable feature and a needle valve looks like I would only need one to control both flows, it can be installed on either port... correct?
I think that probably I will instal one in the ram line also. It could use a slowdown too.
Out of curiosity, are those fixed size orifices problematic with sludge impurities?
/ Bucket Tilt Restrictor #10
I'm curious as to why you need restrictors. Are you just easing your control valves open or
pushing them to the stops?
Usually people want to speed up the response of a loader.
/ Bucket Tilt Restrictor #11
I'm running a 1/16" fixed restrictor on my grapple and it has a single 2" cylinder.
If I would decide on a fixed restrictor, I just don’t know which way to go, 1/16 or 1/32 for the bucket two cylinders. This is why I will probably go with a needle valve.
You do use only one restrictor for your dual acting cylinder, right?
/ Bucket Tilt Restrictor #13
If you start with the 1/32" like I did, you can always go bigger and they drill out easily. Yes, I only restricted on one side of the cylinder.
/ Bucket Tilt Restrictor #15
Does this WFC-8 controls both lines like a needle valve? Just asking because the questions asked on this item points out that it only controls one side unless it is coupled with an actuators, whatever that is.
This valve restricts flow one way and on one line only. I installed mine based on info posted here by others who had what is called bucket flop condition. I posted a short vid of the bucket flop problem and installing the WFC-8 solved my problem. If you install one on the hyd. line that feeds your tilt you can adjust the flow to make it tilt slower without affecting other functions. If you want to slow down curl up and curl down then you need two valves.
Thanks!
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
121A (A63745)
121A (A63745)
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
PALLET OF ALUMINUM PIPING (A67714)
PALLET OF ALUMINUM...
