My new transfer tank set up
   / My new transfer tank set up #11
Frustrating update. I thought I could tack weld the barrel to the frame to keep it secure - turned welder down some - welded lip of barrel to frame then it happened !!! leak ! ugh so I pulled mower around and fueled it and filled up some 5 gallon cans.
After grinding off weld and getting barrel off I decided to build a battery holder while I find another barrel. Was gifted a nice battery from a friend and dug into scrap pile and found enough metal to make a holder. I have all thread and a plate to hold battery when i mount it. somewhere I have an extra trickle charger for my Harley I plan to leave that on the battery.
You welded on a drum with fuel in it? :eek:
   / My new transfer tank set up #12
I put my transfer tank in a small 4x8 trailer.. that way when it needs fuel, I just hook it up to the truck and drive it down to the station. For a power sourc,I use a battery jump pack and the alligator clips right to the jumper cables. For the few times a year that I need to fill machines it is super easy and no aggrition with keeping a trickle charge on anything.
its diesel - not getting it hot enough to burn - i just ran a bead to long and got the lip on the drum hot enough to crack the seam. no biggie. Barrels are easy to get.
   / My new transfer tank set up #14
Way too much trouble.... I've got my 55 gallon drum on a harbor freight large furniture mover.. rolls around on my concrete floor to where I need it, and cost me about $8 and zero time welding. They a rated at well over a full drum of diesel.... which reminds me I need to fill that thing up since fuel has dropped a bit lately.
   / My new transfer tank set up #15
Don't you get heating oil delivered? I'd just get the fuel jobber fill your barrel with ULSD.
no i have an outdoor wood boiler. Just need to fuel the 5400 and the 997 every now and then. Im thinking at worst once a month. Im using the mower more that the tractor and it just sips fuel. If I have to fill it more often I will get a bigger tank I guess.
   / My new transfer tank set up #17
I spent a lot of years hauling either avgas or barrels of water home. Just had muscle power to horse them around. Now that I'm old an puny, I can barely tilt a full barrel up on edge.
If your barrel can be well secured to its frame and can be well secured to your trailer then I guess it would be safe enough. Hope your roads are good and that the station is fairly close. Good Luck
   / My new transfer tank set up #18
Ok, I'll admit this is not in the $8 investment group, but I have got to show it off and it meets the thread title. Tired of lifting 5 & 6 gallon jugs to refuel the airplane (esp. wing tank) with non-ethanol car gas. Considered a stationary tank but delivery charges were outrageous. Wanted an aluminum tank and found a 55 gal. rated for transfer/transport (DOT approved). A used trailer with torsion suspension took a while, but found this used motorcycle trailer on CL which was just wide enough to fit the tank. Had to cut a hinge off to remove the cover of the trailer but it could be replaced. Battery pack is removable. Yeah, I had to put a reg plate on it too. Compared to the similar commercially made trailers ($4k+) I got less than a 1/3 in it.
Informational Lot - Financing (A56436)
Informational Lot...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2001 Dorsey 48ft Flatbed T/A Trailer (A56858)
2001 Dorsey 48ft...
2024 CHEVROLET SILVERADO 2500 HD BED (A58018)
2024 CHEVROLET...
2007 Ford F-750 (A55973)
2007 Ford F-750...
