What is the deal with apostrophes from mobile?
   / What is the deal with apostrophes from mobile? #11
It has been discussed before, the board uses ASCII (which has 128 characters), but those are Unicode characters (Unicode has 137,439 characters).
Aaron Z
There must be more to it than that. Quoting another poster creates Unicode too.
   / What is the deal with apostrophes from mobile? #13
That's messed up. That looked correct in his post but it's messed up when I quoted it.
Hmm, on what devise did you grab the quote and re-post it from?
   / What is the deal with apostrophes from mobile? #15
Itç—´
Wouldn稚
They致e
Don稚
Just checking from an iPhone.
The mobile programing must be Apple friendly, even the slanted apostrophes show up correct.
Quoting on an iPad
If I go back and edit my own post with an apostrophe it will screw it up as well.
   / What is the deal with apostrophes from mobile? #16
Quoting on an iPad
So it's OK on an iPhone and not ok on a iPad. Do the apostrophes mess up on all mobile devices excluding the iPhone, or is it random on all mobile devices?
   / What is the deal with apostrophes from mobile? #17
My original posts from iPhone or iPad are usually ok. The quotes and edits get corrupted ‘’’’
   / What is the deal with apostrophes from mobile? #18
It’s
Wouldn’t
They’ve
Don’t
Quoting from iPhone.
   / What is the deal with apostrophes from mobile? #20
If the quote is from an iPhone and quoted from an iPhone will it always be ok?
Or does it get messed up from the internet sending company or router. My iPhone is wifi from my home router which send through cable internet. Ill try again later when I'm out of range from my home wifi wifi signal and using local towers. My router is connected to a M-Cell that enhances the signal to the iPhone. Could that be the different factor that creates this anomaly?
2008 STERLING LT7500 SERIES (A58214)
2008 STERLING...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2018 FREIGHTLINER...
2023 Load Trailer (A55787)
2023 Load Trailer...
9ft Reading Service Bed (A57453)
9ft Reading...
2010 SHOP MADE LIMA MAC 30KW GENERATOR (A58216)
2010 SHOP MADE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
