1951 8N 30 year tuneup
   / 1951 8N 30 year tuneup #1
wolc123
When I bought this tractor, from the widow of the original owner back in 1988, it only had 1200 hours on it. I have about doubled that number of hours over the last 30 years. These days, I mainly just use it for firewood and on my two-row corn planter and cultivator. The year I brought it home, I replaced the distributor cap, rotor, points, condenser and plugs, with parts from "Central Tractor" in Lockport NY. This year the tractor started acting up a little bit, starting tough and running a little rough after startup when it was cold and damp. Today, for the first time, I was not able to get it started and I drained the 6 volt battery so much trying that it would just barely turn over. I tried a squirt of either, which did not help.
I put a 6 volt trickle charger on it and drove back to that same store (now "Tractor Supply"). They no longer carried Ford 8N parts, not even the spark plugs. I crossed the parking lot and picked up (4) Champion H-12 plugs at NAPA for $10.20. After I installed those, that old flat-head started as good as it ever did, and is running just like a song now. I guess I don't need any of that other stuff. I will have to see how it does when it gets real cold out. I suppose it likes those new plugs. The gaps on 30 year old ones were opened up to about .050 and they were carboned up pretty bad.
   / 1951 8N 30 year tuneup #2
I've got a 1947 2N that I use mostly for brush hogging. As long as I watch that the gas doesn't get too stale and the wiring connections are cleaned up every so often it starts right up. I love these old tractors for basic tasks.
   / 1951 8N 30 year tuneup #3
Sad thing is, you will go a long ways to find a set of points and condenser as good as those 30 year old parts are. DO NOT replace them until they fail.
   / 1951 8N 30 year tuneup #4
A while back, I changed my '51 8N over to the Petronix electronic ignition.
Sometimes sits for over a year, always indoors, but in a coastal environment (damp).
I keep a 6V battery tender connected.
Starts whenever I ask it to.
It has hardened valve seats (engine rebuilt 40 years ago), and I use only 100LL from the local airport.
   / 1951 8N 30 year tuneup #5
Fyi, it had hard valve seats from the factory too.
   / 1951 8N 30 year tuneup #6
Engine was rebuilt (40+ years ago) in a high school engine shop class.
Shop teacher at the time told me that original seats were not hardened type.
   / 1951 8N 30 year tuneup #7
He was incorrect.
All N tractors left the factory with hard exhaust valve seats.
All N tractors except for wartime models left the factory with hard intake valve seats.
check yer N-Ford Master Parts Catalog, you'll find that p/n 52-6057-B, insert, exhaust valve seat; was installed in ALL N-engines 1939-1952. And p/n 40-6057-B, insert intake valve seat; was installed in ALL N-engines 1939-1952 (except 2N's s/n 86271-168259 WW2 production; last 2N s/n 357XXX)
Therefore the answer to your question, your 8N HAS HARDENED VALVE SEATS.
Glad he was a shop teacher and not a heart surgeon....
   / 1951 8N 30 year tuneup #8
He was incorrect.
Thank you!
That was 40+ years ago, and who knows where that shop teacher guy is.
Today though....I do have a really great heart doctor.
I don't use 100LL for it's lead content.
I use it to AVOID ethanol content.
If I could buy UNLEADED no-ethanol gas, I would definitely do so.
   / 1951 8N 30 year tuneup #9
It's scarce here too. Marina, airport or a pump the next city up off the interstate. All of them are at least a 50 mile round trip.
I buy that canned gas for the weed eater to keep it happy.
   / 1951 8N 30 year tuneup #10
I am near Bradenton, and a few gas stations do have it here.
My machinery stuff though, is up in Taxachusetts, where non-ethanol is banned!
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2013 Ford Expedition 4x4 SUV (A49461)
2013 Ford...
(3) 15X8 RIG MATS (A50854)
(3) 15X8 RIG MATS...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
BLAST SHIELD (A50854)
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
