Extra Hydraulics for BX2350???
/ Extra Hydraulics for BX2350??? #1
Musclford
Central, IL - USA
BX2350
I'd like to add another cylinder to my BX... Either for the 3pt and / or a cylinder for turning my plow when mounted to my front bucket...
Anyone done this?
Thanks
Phil
/ Extra Hydraulics for BX2350??? #2
The 2350 has a standard 4 position valve for the FEL, shich should be just fine for a plow angling cylinder...I believe Kubota sells just such an animal.
As far as the 3point, you should be able to plumb in just like the BX24...Just a matter of parts.
/ Extra Hydraulics for BX2350??? #3
I just spoke to my dealer about adding hydraulic remote for top link to my BX2350. Pricing on BX was surprisingly reasonable:
REAR REMOTE HYDRAULICS
BX7322 Rear Remote Hydraulic Valve Kit $ 284.00
BX Series Tractors 3-position
standard type dual acting.
Requires Hose Kit BX7232, BX7324, or BX7325
BX7323 Hose Kit for all $ 174.00
BX Series equipped with LA181, LA181FL-2,
LA211, or LA211FL-2 Loader. (Not compatible
with LA211FL-1 Loader.)
BX7324 Hose Kit for all $ 174.00
BX Series not equipped with loader
BX7325 Hose Kit for all $ 174.00
BX Series with LA181FL-1 and LA211FL-1 Loaders
I was told that the control for this remote would be in the open location on the fender so it would be a very clean installation. I have looked at some of the multi rear remotes the local guys have done on TBN but they are too involved for me and a BX. While a hyd top link would be very handy with a landscape rake and/or box blade, I really can't see the need for a tip and tilt conversion for my limited needs. I told my dealer I would have this done with my 50hr service. Next year so I'll keep in touch on this as I have never seen a posting on the BX hydro upgrade here?
/ Extra Hydraulics for BX2350??? #4
There is my set-up!
$310 CAD, that includes every things, valve, fittings.
/ Extra Hydraulics for BX2350??? #5
skippy957 said:
There is my set-up!
Looks nice but could you expand a little on this?
Did you build this out of parts or is it a kit or Kobota factory?
Where are the control levers?
/ Extra Hydraulics for BX2350??? #6
This is home made. I got a valoil valve from my hydraulic dealer near by and plumb the hydraulic tubes my self. The controls are oriented inside beside the seat.
It is cheep and works great. Here in Canada my Kubots dealer was too expensive around $500 for a kit.
You must use a power-by-on set-up in line with the FEL.
/ Extra Hydraulics for BX2350??? #7
Hi. The installation looks great! Same thoughts as I have! Is there any hydralic diagram for the BX24/2350? Would help alot!
/Sam
/ Extra Hydraulics for BX2350??? #8
skippy957 said:
This is home made.
You did a fantastic job and it is apparent you have created a snow killer Kubota.
See this is where the wheels start to come off the cart for me. I have so little hydraulic knowledge that if I tried this my dealer would get the wind fall then I paid him to straighten my work out.:(
I would really like to see or hear from someone with Kubota factor system for the single remote. At <$400 including labor this looks like a reasonable program for the hydraulically impaired.
/ Extra Hydraulics for BX2350??? #9
There are the 2 hydraulic schema that i fund, it will help, i hope.
  • hydraulic.pdf
  • hydraulic2.pdf
/ Extra Hydraulics for BX2350??? #10
Was that in English? :eek: Now I know I'm leaving this to the experts. :D
/ Extra Hydraulics for BX2350??? #12
I went with the BX7326 Dual Double-Acting Rear Remote Valve Kit for $420, dealer installed, when I bought by BX2350. I'm not sure what the kit retails at; it should be less than $300 plus installation. According to the installation instructions that were included in the paperwork I received, installation is relatively basic.
In my opinion, this is a clean, compact kit with great value.
/ Extra Hydraulics for BX2350??? #13
I"m planning one of these for my 50 hr check
A couple of questions:
1)how many remotes does the kit have?
2)where are the lever/levers located? My dealer told me it would use the open posituion in the upper right fender opening but I'm not real sure on this one.
Thanks
/ Extra Hydraulics for BX2350??? #14
Thanks
rpoage:
(2) I was told the same thing by my dealer. I have not seen the install, but I have heard it is a very clean OEM looking setup.
/ Extra Hydraulics for BX2350??? #15
I looked at a Kubota Whole Goods listing and saw that the 2 remotes were listed as available for the BX2350 but not the BX24. Anyone know the story on that? I can think of things to use the remotes for if they mount as described above. Unfortunately, most of the installs I've seen would be in my way. Any knowledgeable souls that have seen these remotes?? Any dealers care to throw out a bit of info?
/ Extra Hydraulics for BX2350??? #16
Thanks
1. 2 (two) remotes
2. Right hand side, in the open slot. Both levers are in the same slot, side by side. Bends in the levers separate them enough at the knob end to allow operation.
/ Extra Hydraulics for BX2350??? #17
I stand to be corrected, but I believe that the remotes interfere with BH mount, plus the BH hydraulics utilize the access ports that are required for aux. valve installation.
I'm sure that some individuals would be able to install a rear remote or two, but the items used would vary significantly from KB's BX7326 valve kit.
/ Extra Hydraulics for BX2350??? #18
TacoT96 said:
1. 2 (two) remotes
Just the info I was loking for. I'll add this when I have my 50hr done and take some pictures as there seems to by a reasonable amount of confussion on this item.
/ Extra Hydraulics for BX2350??? #19
I'm trying to add pitch and tilt hydraulics to my bx2350 as well. I was unable to open your attachment pic. My Kubota dealer wants $2,000 to install says there is no real kit
They say they custom build for each tractor
Thanks
JR
/ Extra Hydraulics for BX2350??? #20
Thanks
JR
Sounds like you need to find a different Kubota dealer.
The factory kit is bx7326
https://www.tractorbynet.com/forums/kubota-owning-operating/125660-bx7326-rear-aux-kit-install.html
Edit: maybe I mis-understood you. Are you looking for extra hydraulic ports in the back to control the pitch/tilt cylinders or are you looking for a kit that does everything?
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
2012 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2012 VOLVO VNL 6X4...
207281 (A52708)
207281 (A52708)
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
Spray King Pull Type Sprayer (A63116)
Spray King Pull...
2006 Chevrolet 3500 Flatbed Truck (A63116)
2006 Chevrolet...
