Homemade BX25 Ripper Tooth
   / Homemade BX25 Ripper Tooth #11
Great looking ripper let us know how it works out.,
   / Homemade BX25 Ripper Tooth #12
how did this ripper work out for you?
Have not used it yet but should be excellent. I sharpened the whole front of it so it will slice thru roots.
Later:thumbsup:
   / Homemade BX25 Ripper Tooth #14
Nice job.
Does your wife know you have that in the house?
Had about everything else in the hosue at one time or another, might as well have a bx25 in there or parts thereof
later
   / Homemade BX25 Ripper Tooth #16
I have been looking for inspiration, I think this is it.
   / Homemade BX25 Ripper Tooth #17
Agreed... thanks for reviving this old thread. I have been thinking and gathering a few scraps to my my ripper/trencher. Still wrestling if I want more of a trenching (flat bottom shovel) design or a ripper w/ V design for laying buried wire or water pipes around my property.
   / Homemade BX25 Ripper Tooth #18
Try Bro-Tek (bro-tek.com). They have a ripper tooth with an optional trencher attachment that you can bolt on. And, they also made me a quick attach mechanism, so I can swap it out with my BX 25 bucket very easily and quickly.
   / Homemade BX25 Ripper Tooth #19
I made a ripper from a box blade scarifier. Welded a 1/2 chain link on the rear, and secured wires in it to bury. Worked well.
Ron
   / Homemade BX25 Ripper Tooth #20
I have had my eyes on that, and have already have both Bro-Tek and BXpanded accessories. All have been great.
But I cut off both ends of my 72in back blade to make it more compatible with my BX, so I have two 4.5in scraps including the hard cutting edges. Seemed these 'drops' would be perfect for a fun DIY job for little investment. It will look ugly for sure and it that experiment doesn't prove out, I can then fall back on the Bro Tek… It isn't cheap though! :eek:
FORD DEXTER TRACTOR (A52708)
FORD DEXTER...
2003 Ford E250 Passenger Van (A56858)
2003 Ford E250...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
LEINBACH 1R CULTIVATOR (A52708)
LEINBACH 1R...
CAT 350E2 Haul Truck (A55272)
CAT 350E2 Haul...
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
