Mirrors for the RK24
/ Mirrors for the RK24 #1
coastie15078
RK24
I got 2 mirrors for my Rk24 and no drilling required. There were already 2 holes on the FEL and there is enough clearance that nothing rubs.
I did use rubber washers to try and eliminate as much vibration as possible and the best part is, they were only $18.00 for the pair. I use them while backing up the driveway, but once I get close to truck, shed or house, I turn can turn around....it beats being twisted around for 120 feet.....
I have one of those back up cameras, that has the monitor that I bought a few years ago, going to see if I can put that on via a switch, since there is no back up lights to tie it into to activate.....
Not sure if the 19 and 37 has these pre drilled holes on the FEL.
thumbnail_MVIMG_20181207_095921.jpgthumbnail_IMG_20181207_095857.jpgthumbnail_MVIMG_20181207_095903.jpgthumbnail_MVIMG_20181207_095955.jpgthumbnail_IMG_20181207_095912.jpg
https://www.amazon.com/gp/product/B0736JWRMG/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
/ Mirrors for the RK24 #2
View attachment 582005View attachment 582006View attachment 582007View attachment 582008View attachment 582009
Very creative!
Compared to JD want $72.00 per mirror, I think this was a good savings.....going to put a little dab of locktite on as well...
No problem, that's what these ,sites are meant for, to help each other out with ideas. Like I said, I will use mirrors when backing up the drive, but once I get close to the house, truck or shed, I will turn around for a close view.
/ Mirrors for the RK24 #6
Looks like you found a simple ( and cost effective!) solution. There are several styles of those motorcycle mirrors available for not a lot of money. If someone wanted to drill one more hole on each side it would be very easy to mount up a set of aftermarket Jeep mirrors, which would be larger and wouldn't cost a huge lot more. I've seen the Jeep mirrors for $25 set.
I saw the jeep mirrors to, but I didn't want to drill any holes, so this was just a bolt on, quick mirror....
2013 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A61567)
2013 Toro Z Master...
Decorative Pig Statue (A61569)
Decorative Pig...
UNUSED WOLVERINE HEAVY DUTY PALLET FORK FRAME (A62130)
UNUSED WOLVERINE...
2005 Hyundai XG350 Sedan (A61569)
2005 Hyundai XG350...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
