Snow Attachments some thoughts on my snow removal options
   / some thoughts on my snow removal options
I would also question what RPM the folks with tractors are running. My dealer told me that I should run the RPM right up to 3000 . . . but I think I recall someone else saying that they run their sno-blower at 2000 . . .
Oh, I can afford a barn or shed . . . no problem! It's the divorce I couldn't afford if I did build one. The wife is quite adamant about not having any ' outbuildings ' up here on our hill. And in truth, there really isn't any suitable site unless I could sorta cantilever it into the woods. I ' spect the leach field would be unsuitable . . . I'm not worried about my tractor rusting too much before I'm no longer able to play in the snow . . . I might have four or five years more before I'll be wearing diapers . . .
   / some thoughts on my snow removal options #23
What rpm do you run to achieve 540 rear pto speed? I would run that speed at a minimum.
Rated engine speed for that model is 3200rpm
   / some thoughts on my snow removal options #24
I don't know about ' rear PTO speed ' because I don't have any implements which utilize the rear PTO. My sno-blower is front-mounted and operates from the mid PTO. The book sez that @ 3200 RPM engine speed, the mid PTO speed would be 2100 RPM which is the proper speed for this sno-blower. However, 2100 RPM is NOT the impeller speed because there is a reduction ( unknown ratio ) from the drive chain sprocket in the sno-blower to the driven chain sprocket which is attached to the impeller shaft ( which also operates a worm-gear drive that rotates the augers ). The whole drive train for the sno-blower ' seems ' unnecessarily complicated, but I'm not enough of a mechanical engineer to see how it could be simplified and yet maintain the compatibility with the other interchangeable implements . . .
   / some thoughts on my snow removal options #27
atitus - you must still be a working man. Otherwise - when retired like me, look out the window - check the temps - make yourself another hot toddy - wait for daylight - then decide if the snow is REALLY that deep. Get all bundled up - pour yourself a straight shot and go out and brave it.
When I worked I would go out in the dark of night and plow the driveway. ONLY because, when its snowing here I usually can't get thru to work on my cell phone and let them know that I was snowed in again.
I read an article by a mechanical engineer working for Schultz - farm equipment manufacturer - paint all their equipment lime green.
The main point I got out of the article - its not so much the rotational speed of the impeller as it is the power driving the impeller. As he stated - you can throw a lot more snow with 50 PTO hp and the impeller rotating at 300 rpm than 25 PTO hp and the impeller rotating at 600 rpm.
Idea being - - its brute force over rotational speed that will move the most snow.
   / some thoughts on my snow removal options #28
With pretty much any implement, the manufacturer will design it such that it operates best at a specific PTO speed. For rear implements this is usually 540. For mid-pto it varies more, but 2100 to 2300 seem typical. The tractor manual should tell you what engine RPM to use to achieve the expected PTO speed. In the case of my tractor there are markings on the tachometer so you can line up the needle with the 'PTO' and away you go. Many people will report they like to run it at a lower PTO speed for whatever reason. Highly doubt you'd damage the equipment by running it at a lower speed. If someone said they liked to run it lower, I would just ask why -- if they explain what they got out of it you may find out if that same thing would help you or not.
   / some thoughts on my snow removal options #29
Ha ha ha yeah you are right about that. My wife is a teacher, and she has to leave very early in the morning too. Call it late at night or really early in the morning, more often then not I have to clear it in the dark. We don't find out until last minute sometimes if school is cancelled.
   / some thoughts on my snow removal options #30
Living out here in the sticks - I've always had a 4WD. So - some evenings - look out at the snow - go to bed and drive to work the next morning without plowing.
What would frost my cookies - get up at 2AM. Dress up like an Eskimo - open station tractor - go out plow the yard, mile long gravel driveway and mail box area. That took three hours. Come back inside - take a nap until 7AM - then to find that the county had not yet plowed the county road. I could putt along and make it to work - sometimes needing 4WD - but realized the boss drove a big 'ol Buick and wouldn't be there and would leave a message on the phone - closed due to snow today.
That got to be real old - real soon.
   / some thoughts on my snow removal options #31
I can't agree with this. The impeller running at 600 rpm has a lot more kinetic energy than one running at 300 rpm independent of the power of the engine that runs it. Now, if the snow was heavy enough to bog down the engine, this would make some sense but that doesn't happen. I've got 18 hp at the PTO and the engine rpms never vary when snow blowing. 100 hp would not put more energy into the snow that's being moved.
   / some thoughts on my snow removal options #32
It depends on what you are disagreeing with. If you are talking about VOLUME of snow, then yes. The chute has a specific diameter, like a water pipe. There is a limit on how much snow will be able to pass through, aka flow rate. Once this flow rate is reached, it won't matter how much pressure/force you put behind it, the flow rate will not increase. Assuming that 18 hp will have sufficient pressure to max it out, then doubling the HP would have no effect.
If an engineer is building a snow blower designed for a 50 hp PTO, chances are they are going to add a bigger auger, wider chute, etc versus one designed for 18 hp. The impeller may run at a slower RPM however it will move more snow volume not because of its power but because of the flow rate of it being larger. It will need more power to move the larger amount of snow at once.
Don't believe it? Here would be the proof. If you set up an experiment where you took a snow blower designed for an 18 hp tractor and hooked it up to a 50 hp tractor, the volume of snow moved would not increase by much. That is of course assuming that the manufacturer who built it made sure that 18 hp was enough to maximize the flow rate.
   / some thoughts on my snow removal options #34
Your talking about 2 different sized blowers.
I never saw that mentioned.
   / some thoughts on my snow removal options #35
Pretty sure I applied this theory to a single blower. Last 3 sentences of my post?
   / some thoughts on my snow removal options #36
Like a water pipe? The way I take what you are saying is, if we take a 1" water pipe it will only let so much water through, regardless of how much water pressure there is?
   / some thoughts on my snow removal options #37
WoW - mellow out guys. I didn't intend to start a flame war. I would love to discuss this knowledgeably but since I'm not a mechanical engineer - no joy.
   / some thoughts on my snow removal options #38
Yeah you got it. Crazy isn't it? Increasing pressure can increase the flow velocity (how fast does it flow) but not the total amount of flow passing through at any one time.
   / some thoughts on my snow removal options #39
Not to beat a dead horse but...
You can move more snow at 300 rpm and more horsepower than 600 rpm and lower horsepower... but not with the same snowblower. The amount of snow is based on the volume displaced by the impeller and the distance thrown is based on the tip speed of the impeller, so to take advantage of the high horsepower at low speed you would need a much larger diameter impeller.
If you look at an 8 foot wide blower compared to a 5 foot wide blower you will see a much larger impeller. As impellers get bigger, eventually you would have to slow them down because of high tip speeds but I think most of the commercially available 3 point blowers are designed for 540 rpm. The bottom line is that if you can run at rated speed without bogging down the engine with a given snowblower, more horsepower would not make a difference.
As a Mechanical Engineer who did his masters work in fluid dynamics and design of rotating machinery, I'm sure the engineer at the implement company was correct that a blower could be designed to deliver more flow at lower speeds but it seems to not be a practical point.
If you want to move snow and already have a snowblower, run it as fast as you can.
   / some thoughts on my snow removal options #40
Not true. As pressure increases flow increases until you reach sonic velocity and the flow chokes. I don't think choked flow is in any way possible with a snowblower.
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
Adams 5T Fertilizer Spreader (A56438)
Adams 5T...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
