Oil & Fuel 4110 Hydraulic Issues
/ 4110 Hydraulic Issues #1
Mahindrahunter
Mahindra 4110
I bought a used 4110. I went to run my bush hog over the summer. When I engaged the Pto, it at first didn稚 want to operate. Had to rev up the rpm痴 to get it to finally run.
Ran fine for a little while then noticed the hydraulics stared to shutter. Stopped using the tractor for a little while. Ran it a couple weeks later, hydraulics still shuttering. I changed the hydraulic fluid and all the filters. Fluid and filters were pretty bad. I ran the tractor after the service. Everything ran great. Parked the tractor for a couple weeks. Ran it again and the hydraulic shuttering came back.
Kind of at a loss.
/ 4110 Hydraulic Issues #2
Can you define shuttering hydraulics? Loader is shaking, steering is jerky etc?
Well I wish I had a FEL! Anyway, the 3pt shakes a little when raising it. The steering will get tight, kind of like it lost power steering. The last time I ran the bush hog (been a little while) it would spin, but when I got in heavy brush, it would want to slow down or stop like it was slipping.
/ 4110 Hydraulic Issues #4
Kind of at a loss.
Pump is cavitating ! Suction leak or clogged sump screen. Pump maybe starting to fail. :eek:
Any advice on what to check first to try and narrow down the source of the issue?
/ 4110 Hydraulic Issues #6
You will need to hook up a pressure gauge to see what that is doing. Pull the filters and see what’s going on in there. Getting to the pickup would require a manual or good understanding of how that particular machine works (not me).
Have you ran the machine and cycled everything lock to lock 15-20 times to verify it’s not just some air?
The only thing I haven稚 tried running is the pto. I don稚 have a FEL. I have operated the 3pt quite a bit. Like I said, right after I changed the fluid, everything ran good. I would have thought if it were air it would have been an issue then. When I changed the hydraulic fluid, it was pretty nasty. Filters, I thought were pretty gummed up.
/ 4110 Hydraulic Issues #8
You've got the large, canister suction side filter under the tractor - it's easier to drop the whole heavy metal canister and separate it to change the filter inside. Then you have the pressure side filter which is the spin-on on the upper left of the rear axle. Then you have the suction screen in the bottom of the trans. assembly - it is held in by 1 bolt on the left side of the lowest spot of the trans case. You remove the bolt and twist it out - it has an "O" ring that seals it to the case. Of course all the trans fluid has to be drained to change/service either of the suction filters. Good luck with it !! Oh yea, the PTO is an electro/mechanical independent. Hydraulic pressure is used to engage the PTO clutch via the electric solenoid mounted on the right side of the trans case.
I just changed all the filters probably 5-7 hrs ago. You suggesting I need to do it again?
/ 4110 Hydraulic Issues #10
did you clean the suction screen? If the fluid & filters were dirty when you changed them the suction screen must need cleaning.
Must have overlooked that part. Sorry, but where exactly is the auction screen located? I changed the suction filter (big filter/ canister below the right side). I only changed the fluid and filters. It all was pretty dirty. Guess I need to change them all again? The fluid was the cheap part. Could I get by with using the same filters?
Skipmarcy, I replaced the suction filter screen when I replaced the other filters. The suction filter screen was really dirty? Wonder if I need to do it again? Like I mentioned earlier, once I changed the fluid and filters, it ran great that day. Just had problems after it sat a little while.
/ 4110 Hydraulic Issues #13
I can't really advise you to change everything again having not been there to see when you first changed it all. Sure, there's a possibility it might need it again if it was extremely nasty inside the case(s). It's a large area inside with all kinds of nooks & crannies. If it were me I might take the loss on the hydraulic fluid and at least look at & clean the suction screen in the bottom and see what you see for contaminants. If it's clean, obviously you need to look into a mechanical malfunction. If the screen is really nasty again, I'd change the 2 filters again as well. The screen is easily cleaned in paint thinner, kero etc. as long as it's not punctured anywhere. I always put a little axle grease on the o-ring when re-installing.
I might do that. Take the screen out and check it and go from there. Thanks for the help.
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
500BBL WHEELED...
YANMAR VIO55-6A EXCAVATOR (A63276)
YANMAR VIO55-6A...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
