How cold can I apply fluid film?
   / How cold can I apply fluid film? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Just picked up a new trailer I ordered about September. I'm in northeast Mississippi.
Temps are supposed to get up to 62 deg F today - do you all think I can apply fluid film from aerosol cans or is it too cold?
   / How cold can I apply fluid film? #2
I have yet to get/use fluid film. So I'm guessing there are no environmental operating temps listed on the can. If you are only concerned about getting the stuff out of the can - put the can in a pot of warm water and let it sit for half an hour. Everything I've ever used is safe up to and including 100F. Many go as high as 120F.
So you don't have a thermometer to check the water temps - water at 120F will be VERY uncomfortable to stick your hand into. As a matter of fact - at 120F you will jerk your had out PDQ.
Safety Data Sheet for fluid film. In storage do not expose to temps above 122F.
You might want to check further - Google - - Fluid Film- MSDS. There were MANY links - I looked at only one.
   / How cold can I apply fluid film? #3
Absolutely at that temp. just shake that rattle can. I just sprayed a little the other night, some with the little straw attached, on my truck toolbox mechanism and it sprayed fine. The temp. was a cold and damp 30 degrees.
Btw, the can I used was in the unseated barn the whole time where temps had been in the upper twenties/low thirties the whole time.
Thanks, that's about what I was hoping to read. I've got it in gallons also but I know it's very thick at those temps.
And the application relies on the temp of the surface I'm applying it to also.
Maybe I'll try to warm up the undercarriage with a salamander.
   / How cold can I apply fluid film? #5
Thanks, that's about what I was hoping to read. I've got in gallons also but I know it's very thick at those temps.
With the approach you outlined, you can't go wrong. And it will be nice to get it on a new trailer before use! Post back how it went when done.
Works, temp "shot up" to about 65 deg F. Spraying Fluid Film on the air temp metal from a warm-to-touch can resulted in a nice film with some drips. Stuff didn't congeal like I was concerned about.
Didn't use the salamander.
/edit
Finished off about 3 cans for the frame.
Wind came up towards the end but since it's mainly lanolin it didn't bother me.
Sure beats rubbing sheep to oil the undercarriage:)
2018 CATERPILLAR 336FL EXCAVATOR (A51242)
2018 CATERPILLAR...
BOBCAT QUICK ATTACH HYD SOD LAYER (A51244)
BOBCAT QUICK...
Skid steer auger plate (A50322)
Skid steer auger...
2018 ATLAS COPCO V4 PORTABLE S/A LIGHT TOWER (A51243)
2018 ATLAS COPCO...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
