What to use for a level indicator for forks?
   / What to use for a level indicator for forks? #31
Yeah, somewhere along the line one has to use a wire (power, and likely ground), which kind of defeats the notion of avoiding issues of snagging wires (which I'm quite familiar with:eek:). I tend to think that a wire is essential for a reliable video feed.
Trust me...just get the hard wired ones with the 4 pin cables...only way to go
   / What to use for a level indicator for forks? #32
Could you elaborate why you believe one should go with 4-pin cables?
   / What to use for a level indicator for forks? #33
The power and video are all is one wire so you dont need to run 2 sets. The wireless still requires a power wire. Here is my setup... 20181201_162546.jpeg20181201_162559.jpeg20181201_162515.jpeg20181201_162503.jpeg20181201_164638.jpeg
   / What to use for a level indicator for forks? #34
Two wire cables are usually molded together, thus basically making up one cable. Installation and maintenance would tend to differ little. I was thinking that it was perhaps the benefit was for video stability.
I'll note that LCD monitors take a bit to warm up before you get a stable image. Incentive to allow the tractor's fluids to also warm up a bit before use:D
   / What to use for a level indicator for forks? #35
4 pin cables are better video quality than RCA
   / What to use for a level indicator for forks? #36
I had auto leveling loader on my New Holland. My Kubota MX doesn’t. My eyes don’t have any problem leveling the forks to pick up pallets
Andy
   / What to use for a level indicator for forks? #37
OK, I'll keep that in mind when I upgrade my entertainment system in my tractor (to watch movies) :laughing:
   / What to use for a level indicator for forks? #38
Lol...I hear ya. I have a bad back, so not having to turn around as much is helpful. I may look for an XBox too. Lmao
   / What to use for a level indicator for forks? #39
ONE thing I have thought about, given tech trends and price drops, has been a video camera, or several with split screen display.Back up cameras are CHEAP these days, fairly rugged and adaptable - depends how much Inventioneering Ya wanna do.---------------------------------------------------.
If you get a back up camera, make sure the image is reversible. Back up cameras have a wide field of view, which is great for backing up, but not great for positioning fork tips.
I have a 53 degree field of view camera on the front and it is very handy. :thumbsup:
   / What to use for a level indicator for forks? #40
This is on a Kubota M7060 cab tractor. The cameras are mounted on magnets, so easy to move.
The magnets don't interfere with the camera signals ???? Thanks as I would like to do the same thing with my M5140 Where did you get the cameras and magnets
UNUSED IRANCH IRTPL 10,000# TWO POST LIFT (RED) (A57193)
UNUSED IRANCH...
1000000 (A47477)
1000000 (A47477)
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
TANK MANIFOLD (A58214)
GROUNDHOG ZH12G EXCAVATOR (A57192)
GROUNDHOG ZH12G...
