What to use for a level indicator for forks?
   / What to use for a level indicator for forks? #11
Slow down.
Generally I look at the fork tips. The only time I break pallets is if they are frozen to the ground in winter or I am or the pallets are on uneven ground and one fork is sitting higher.
If your pallets are stacked level then any other breakage is usually due to operator error.
   / What to use for a level indicator for forks? #12
   / What to use for a level indicator for forks? #13
On my B7800 I'd just stand up and look over (I used 3pt forks chained to my bucket- yeah, cheesy, but it worked). My Kioti NX and the cab is a different story...
Aggravating for those that do not have a clear view. It's for this reason I installed a camera system in my NX. Unfortunately I have yet to install a replacement camera after blitzing my first one: I'm trying to come up with a reasonable design that allows me to be able to move the camera around while still protecting the camera- I am close to a solution, but have yet to prove it out (doesn't require welding as I do not have a welder, so I'm a bit handicapped/limited).
   / What to use for a level indicator for forks? #14
I'll add that it's not just whether the works are "level," but that they're correctly positioned. Lots of times having a slight drop in the tips is warranted, in which case "level" isn't of much help.
I operate on uneven ground. While I might be honest I'm certainly not operating on the level!:laughing:
   / What to use for a level indicator for forks? #15
Any low cost back up camera system would be the most cost effective IMO.
As suggested U could mount the camera on a magnet base.
With a camera system you would be able to work on all sort of uneven ground situations.
Many of the back up systems can take 2 camera inputs and the ones I am familiar with have options for front/back and flipping of image.
Also wireless or wired options exist but always the camera wants DC power.
One downside is the wireing is of such a small gauge that U need some sort of protection for a tractor environment.
I am using a $50 ish offshore system for slightly over 3 years now with no problems, mainly for snow blowing duties.
I used magnets for my mounting and placed the viewer low center of my windshield.
If not urgent EBay and AliBabba are good sources.
   / What to use for a level indicator for forks? #16
^^^ And you inspired me on this. I went with a nice magnetic base, as that allowed me to move the camera around. The magnet I had was really strong and the camera's thin metal attachment base not so strong. But for those that are more careful (I think I bliitzed mine removing snow out on our local road) it's the best solution.
   / What to use for a level indicator for forks? #17
I would love to have one of those camera set-ups. One pointed rear to watch 3pt work, and one pointed at the QA implement.
   / What to use for a level indicator for forks? #18
Not sure what brand my forks are but, the SSQA design makes my forks level when my indicator shows level.
Still a pain if on uneven terrain. If I tip my forks up a bit I can see the ends. Soon as I level them they are gone...
   / What to use for a level indicator for forks? #19
I have HD mercury switches I was always gonna make something out of. If someone made a wireless magnetic sensor that indicated degrees to a good resolution, that would be sweet!
   / What to use for a level indicator for forks? #20
If you mistreat your pallets, they may run off and hide in some far off field ...............
UNUSED PABREAK RT260 - 72" HYD TILLER (A57193)
UNUSED PABREAK...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
air compressor (A55758)
air compressor...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
