Yanmar 2210 D
/ Yanmar 2210 D #1
prosekalo
Россия
Yanmar 2210d
Объёмы для замены. проверено мной лично все точно
/ Yanmar 2210 D
/ Yanmar 2210 D #3
Thinking the translation is: "Volumes for replacement. I personally checked everything for sure"
Not sure how or if this relates to your 2210D? The EF312T and EF352T are quite different.
/ Yanmar 2210 D #4
What do you think California. Vol. and Fuel in English to me? as far as the chart goes? Translation is that.............
/ Yanmar 2210 D
This table was given by a Japanese man with my 2210, they are the same.
/ Yanmar 2210 D
replacement was recently and all volumes matched
/ Yanmar 2210 D #8
Keep it clean. My 2000 has no signs of being a VN'er.. But it was apparent that the screen had been replaced on it. They kept the ends and cut and replace just the screen and then ran a welded down it. It worked and Fantastic. I replaced it from being so dirty. But I cold tell what had been done. It was still all intact. So it worked good. They used another screen from a larger tractor IMO.. Just some thought. Hoye doesn't show it or does my Parts. But what it does show is maybe and should able to use the screen 330,2500,3000 and see if you can replace just the screen. The 2210 is a pretty common model so I would think Hoye either has it New, Used or a remedy like I just said. A member on here asked for the old one Yrs.and Yrs ago never heard anything more about it afterwards.....
/ Yanmar 2210 D #10
Prosekalo said he found the correct volumes.
That chart is for tractor EF312T and EF352T, 3-cylinder models from 2007 - 30 years newer than his 2210. And the oils specified in that chart are now obsolete - 'CD 30 or 40 grade motor oil', Deere J20B transmission fluid. There are now better products available.
Prosekalo, for engine oil I suggest use the same modern diesel oil as big highway trucks use in your country. And for the transmission, a modern tractor transmission fluid that says it is compatible with John Deere J20B. The 90 weight gear oil in the chart for the front axle is ok but I think modern 85W-90 grade is much better for low temperature use.
(2) UNUSED 380/85R30 TIRES W/ 10 LUG RIMS (A64280)
(2) UNUSED...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2005 Trail-Eze TE70HT53 42 Ton Hydratail T/A Drop Deck Trailer (A61573)
2005 Trail-Eze...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
