My Kubota is causing me pain!
/ My Kubota is causing me pain! #1
almost canadian
Calgary, Alberta
Kubota L4600
I apologise in advance for the rant but my blood is boiling somewhat.
Almost 5 years ago, I bought a L4600 with front end loader. We live on 20 acres in Alberta, Canada and we have horses so I needed something that would be able to lift 1,200 lbs round bales and assist with ploughing snow from our drive. With a blade attached to the 3 point hitch, a bale spear attached to the 3 point hitch and a bale spear attached to the FEL it worked a treat.
It doesn't get much usage and it only has 104 hrs on it.
At the 44 hour mark, we had an issue with the HST (the wheels didn't move) and it was fixed under warranty (around the 2 year old mark). On Saturday, I was clearing snow from our drive and just before the HST packed in again, it was working, but was going very slowly when the pedal was put right down. I am not a mechanic but I have driven enough manual cars to imagine that it was acting as if the clutch was slipping. It did this for about 2 minutes before coming to a halt.
The dealer that I purchased the tractor from lost their Kubota franchise about a year after I purchased it and it was given to another dealer. They were the ones that dealt with the previous issue. We paid one of their guys $150 to come out yesterday and look at it. He told us that this shouldn't have happened at this stage of the tractor's life but he couldn't tell us what was wrong with it. The dealer called us later to say that for the princely sum of $250 they would come to our place, take the tractor back to their shop on a flat bed and would then charge $150 to resolve the issue. When we asked them what their estimate to fix it would be, they told us "around $2,500 but we won't know until we look at it." When I asked them what their guy had been doing they had no real response.
The tractor cost me $35,000 and, in 3 months, I will finish paying for it. I had hoped to have an asset but it appears that I now have a very expensive pile of junk.
If I knew that the $2,500 would resolve the issue and I would get some good use out of the tractor, I would, grudgingly, pay it. However, I don't want to drop $2,500 simply to have this happen again in another 50 hours of use.
My gut is telling me to fix it, sell it and start again, steering well clear of Kubota.
Any advice would be greatly received.
/ My Kubota is causing me pain! #2
I am not a hydro fan but it seems strange to have one going out that often.
Kubota has a good reputation. What was done to the tractor at 44 hours?
Untill it gets checked out carefully it would be impossible to estimate true repair cost.
I have seen the troubleshooting cost as much or more then the actual repair.
Not knowing how it went bad or why a different brand may not be any better or it could be worse.
Good Luck
/ My Kubota is causing me pain! #3
I'm sure you checked the fluid levels and they are ok and the correct fluids were used at the 50 hr service. 100 hrs is nothing. This sounds like an ongoing extension of the first problem you had. I would go ahead and find out what is wrong with your tractor and then get the Kubota rep involved if it wasn't fixed right the first time (or even if it was). One way or another, you must get it fixed. I would try to get Kubota to cover your costs.
/ My Kubota is causing me pain! #4
I agree with skipper. If this is the same issue that was already repaired, it obviously was not done correctly the first time.
/ My Kubota is causing me pain! #5
The hours are low but it seems that you might have changed the hydraulic fluid once in five years which could be the issue although I have seen others go longer. In your climate much like NY where we live i tell people no more then two years if not stored in a heated building. Condensation builds up when stored in cold.
/ My Kubota is causing me pain! #6
Can you give more details about the symptoms of the problem? I really doubt you’ve burned up 2 clutches but I suppose it’s possible.
/ My Kubota is causing me pain! #7
Making contact with Kubota would be my first action. Either way you'll be fixing it to sell or keep but hopefully Kubota will step up and take care of it.
The issue at 44 hrs appears to be the same one I am having now. My wife was using it at that time and she cannot remember what happened prior to it stopping. We have had the dealer check the fluids at every 2 year point.
Insofar as what has gone wrong, I really don't know. Everything works fine with the exception of, when the pedal is pressed, it won't move backwards or forwards. There is no grinding noises, it is almost as if it is in neutral.
It is kept in a heated Quonset too, so it almost looks brand new.
We went with Kubota in the first place as a result of their reputation for being bullet proof. Wife will be speaking to the area rep today so, hopefully, they will resolve it.
However, my real issue here is what to do with it once it is fixed? I don't want to be worried that this is going to be a recurring problem.
/ My Kubota is causing me pain! #9
Three thoughts here...
Get "Kubota" involved (even though maybe out of warranty) ...
Get any work done at "new" dealer...
Maybe the problem (and many others may have experienced) is why "old" dealer lost franchise...
Dale
/ My Kubota is causing me pain! #11
If it is any consolation, it is extremely rare to have problems with Hydro's of any brand, and Kubota in particular. I believe your problem is related to a relief valve in the Hydro. A pressure test on the hydro would confirm or deny that. It is not a complicated procedure and can be done without opening the transmission. I assume this problem manifests itself in any range?.. Remember the range selector is just a non complicated manual transmission behind the Hydro motor on the way to the final reduction gearing.
As others have said, I would try to get the Kubota field rep in on this as soon as possible.
/ My Kubota is causing me pain! #12
Is the park brake engaged ?
I suppose that is a possibility ,but in low range most of them will over ride the parking brake and move anyway, although a bit sluggish, and in high range the hydro would whine like a banshee. I would think he would notice. :)
Dale
Kubota are involved and have stated that they will speak to dealer so that the dealer can get back to us.
The old dealer are out of the picture at this time, we haven't spoken to them at all.
I appreciate that the old dealer may have screwed something up but, if that was the case, one would have expected the new dealer to have resolved the issue when they previously dealt with it at the 44 hour mark.
Thank you.
Would this not have been discernible when the dealer's rep attended yesterday, or does it require the tractor to be taken to the shop? The guy that attended had a huge amount of equipment with him.
The first thing I thought was that I had knocked it so that it was between the ranges. Checked all of them and none worked.
Brake was not on and we always use it in mid range. As I said, there were no noises at all, when pedal was pressed, nothing happened.
/ My Kubota is causing me pain! #16
Understand. A pressure test is simply a high pressure gauge (5000+ lbs.) attached to a pressure port on the hydro. This will tell you if the pump is making pressure . I didn't' figure the parking brake was on, but hey it doesn't hurt to ask. :)
/ My Kubota is causing me pain! #17
Was it below freezing when the problem happened? Was it below freezing at the 44hr mark?
/ My Kubota is causing me pain! #18
Are you thinking water from condensate in a very underutilized transmission?
/ My Kubota is causing me pain! #19
What everyone else has said which is why the quality of the dealership is about as important as the tractor. One dealership told me to go pound sand another got me a brand new engine after the warranty had expired. He determined had missed something earlier. The last new machine we bought was a John Deere. Our present Kubota dealer took the place of one who had their contract canceled due to poor quality of work. There is a dealership eighteen miles away, but I travel the extra thirty or so miles to a good one.
Traditionally, if a tractor wasn't going to be used much, we bought a used one and you will find my brother on an old Ford or Case as often as a newer one.
Best of luck in resolving your issues.
On Saturday it was around 0 celcius. Not warm but, in my neck of the woods, not particularly cold either. I have used the tractor in -30 celcius without issues in the past.
I can't recall if it was below freezing at the 44 hour mark, but it wouldn't surprise me if it was.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
Zero Turn Mower (A59231)
Zero Turn Mower...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
Pallet of Forklift Safety Basket (A61567)
Pallet of Forklift...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
