   / Harbor Freight Tools that don't suck #10,421
I received the replacement 18V tools today.... Sorry Harbor Freight... Your price is too high and your warranty is to low.
   / Harbor Freight Tools that don't suck #10,422
I'm returning them
I found the Ridgid 5 tool deal for $279 and ordered that. For around $80 more I'll have the 1/2" impact, 1/4" impact, drill, 4.5" grinder and LED light plus a 2 amp battery and 4 amp battery and a single charger.
I can't pass that deal up.
Yes I know, earlier in this thread I said bring the HF stuff back and buy the 5 tool deal. It's great having a battery powered cutoff wheel at your disposal. So I'll be waiting for your review. :D
   / Harbor Freight Tools that don't suck #10,423
I have a task that needs done this week. I loaded my buddies 11,000 lb skid steer into my trailer and ripped the rear supports clean off of the frame. So I need to grind the 2" round tube mounts clean and also grind the trailer frame clean, then weld it all back together. I'll charge up the Ridged batteries and attempt to do all prep work with the new tools.20181121_082808.jpeg
   / Harbor Freight Tools that don't suck #10,424
Guess what came!? I'll get them charged up this evening and start grinding.20181127_050934.jpeg20181127_051003.jpeg
   / Harbor Freight Tools that don't suck #10,425
Guess what came!? I'll get them charged up this evening and start grinding.View attachment 580628View attachment 580629
Nice kit. I have many of the Ridgid 18 Volt tools and I'm interested in how well the angle grinder works for you. I already have three corded grinders but, have an application that battery powered would be very helpful.
Looking forward to your review.
   / Harbor Freight Tools that don't suck #10,426
RockCrawler, out of curiosity, would you mind putting a voltmeter on the Ridgid 18v batteries once you have them freshly charged? Wondering if they will read 20v. I suspect they may use the same cells as the Hercules 20v and Dewalt 20v batteries, but are just described differently, like Milwaukee (maybe to comply with European marketing requirements?)
   / Harbor Freight Tools that don't suck #10,427
There's no difference between 18v and 20v tools. It's a marketing spin. 2V Max Vs 18V Batteries, Which Is More Powerful? - CDZ
   / Harbor Freight Tools that don't suck #10,428
   / Harbor Freight Tools that don't suck #10,429
Since I still have the Hercules in the boxes, I can test them side by side tonight. I'll report back.
   / Harbor Freight Tools that don't suck #10,430
My experience with the Ryobi 18v string trimmer - it would be fine for urban lawn grooming. My actual use is to cut foot-high straw that is too close to the deck columns to cut with the tractor and rotary mower. This works, but cutting material that coarse breaks the string continually. And refilling the spool is a PIA. Buy a couple of extra spools to swap in mid-job!
I would like a tool powerful enough to trim the blackberry runners that threaten to go up my orchard trees - this isn't it.
Mine was a great buy in near-new condition at Goodwill for $10. Next time I dropped stuff off there I found the leaf blower for $7. Again, this blower is sufficient for minor use but its not up to moving windrows of large wet leaves.
I see there are several models of Ryobi 18V string trimmers and leaf blowers. I'm talking about the models in this photo. Here's the review article where I found the photo.
I gave up and bought a Honda. While it's not the best ergonomically the 35cc 4 stroke cuts through anything I throw at it. Being a 4 stroke it's quiet and no 2 stroke smoke. It came with a saw blade and anything under an inch think it doesn't even notice. I would assume all the 4 stroke trimmers on the market now are like it. When I'm done using it I shut the fuel off and let it run until it dies. Then I just drain the fuel out of the tank back into the gas can so it never have fuel in it that can go bad. But we have a long winter up here so it will sit from August until May without being used.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
205196 (A52706)
205196 (A52706)
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
