My tractor is 55 hp MFWD and about 8000# so might be a little light for the 950. However, I need a heavy blade, the ground here is almost like concrete when it's dry. I have a wide range of soils that I have to deal with including the occasional rock. I do have and have used and understand how draft control works. On a different tractor I've had a rear blade without a tail wheel before and added one later on, but it was way to light to accomplish anything, but the tail wheel showed promise for what I wanted to do.
I appreciate all your inputs. So, I plan to talk to my dealer mid December to see what the cost is both with and without the hydraulic cylinders. And I'll check cost of both skid shoes and tail wheel. I will need to add the electric solenoid valves to the tractor so that's an additional cost. I've checked the auction sites to see what's available and was surprised at the listed prices, so I'll have to see what the dealer comes up with.
As for the hydraulic solenoids - I found a set available thru Summit Hydraulics and I'm sure there are others, but have not found quite the configuration I want other than Summit's. So a question for MtnViewRanch - where did you get your's?
And does anyone have the hydraulic cylinder sizes for the blade so I can see how much the price difference is with generic vs rhino cylinders?
