ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,474
- Location
- southern wisconsin
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
I have used lots of those McMaster-Carr couplings and they are a quality product.
5. Devise two piece fan assembly; cut a fan in half, drill 2 more holes, make a two 2 piece thin steel plates matching holes on the coupling, drill holes to match the fan and tap for 1/4 bolts. Install he plates offset of the cuts. Looks like the fan bolts can be accessed (not easily) from underneath
Numbers 1 and 3-5 have been done by various posters, 2 is the OPs unproven idea. 5 is my unproven pet idea.
Thanks well thought out reply Ron. I have seen most of your ideas in different posts by different people - many creative ways to address this out there.
For the coupler I was looking at the clearance to separate them in the future...hopefully enough there - will be tight. I figured worse case is I have to spend another $75 for a new shaft if it doesn't work out. Never dealt with couplers - reason I am asking here in the first place. The one I linked uses eight bolts to tighten it down, supposed to have solid tight friction clamping. Appears to be the best one of the various couplers I have found for higher torque and RPM ratings and I trust McMaster to be accurate about those. Not sure how that would be loose when mounted like you mention you have seen in the past. I figured that would be an issue with ones that only used set screws to hold them in place.
Thanks for your reply!
4. Devise a an oil cooler system to cool the oil externally with a tranny cooler and fan fabrication.
For anyone that did not see the original thread, here is a link to it.
https://www.tractorbynet.com/forums/kubota-owning-operating/212864-bx25-transmission-filter-relocation-cooler.html
Here is someone who did exactly this.
BX24 HST Fan Replacement - OrangeTractorTalks - Everything Kubota
