Plasma cutter question?
/ Plasma cutter question? #1
BHD
easten Colorado
JD 4020
I am interested in getting a plasma cutter,
and I want a good unit, but I look at, hobart, lincoln, intertherm, and running in the $1500 +range for a 30 amp unit,
and see east wood, and harbor freight, woodward, some others, (yes i know there imports), but the price of the units are about a third of the name brands,
one thing I want is to be able to get the consumables,
would like to be able to cut nicely 3/8" and the first project was to make some item out of sheet metal 24 to 28 gauge.
any advice?
/ Plasma cutter question? #4
I think my Hypertherm 45XP is the greatest thing ever but I've never used anything else.
/ Plasma cutter question? #5
I have owned quite a few plasma machines that I use in the field for stainless work and the ones that held up best were the ESAB and Thermal Dynamics units, they seem to have the best torches and even the tips and cups last longer than most other machines I have owned.
/ Plasma cutter question? #6
Cheapo machines become expensive paperweights after you discover you cant buy spare parts to keep it running. You get what you pay for. You will have more luck and better quality on well known name brands vs Chinese junk.
You dont save any money going cheap on tools because in the long run you end up spending more buying it twice.
/ Plasma cutter question? #7
All good advice so far.
I have two Millers. My top three choices would be Hypertherm, Thermal Dynamics, Miller in that order.
/ Plasma cutter question? #8
I've had three Millers. Liked them all.
I would never consider purchasing a 2-3 hundred dollar cutter with the expectation to quality cut 3/8".
Come to think of it,, I can't think of any reason I'd buy a 2-3 hundred dollar cutter....
/ Plasma cutter question? #9
My only complaint with Miller is that they overate their cut capacities. Or perhaps they’re over rating my skillset....
/ Plasma cutter question? #10
I agree Terry. I've got a portable 625 now. It's excellent on 1/4". Over that and the speed drops off dramatically
/ Plasma cutter question? #11
Same with my 625, Richard.
Case in point. I’m still in the process of setting up this Miller 1251.
1 1/4” @ 10 inch per minute. We shall see,but I highly doubt it!
/ Plasma cutter question? #12
Oh wow Terry!!!! I'd like to hear how that works!!!! Start a thread or something. That thing is a beast!!!! :)
/ Plasma cutter question? #13
Although I have others, I like my little Thermal Dynamics Cutmaster 42. 115/230. Lops off 1/2" when needed but I like the smaller SL 42 torch that offeres V2S Vent to shield technology. It uses less than half of the air that the larger SL torches and every other brand use. Somthing like 3.2cfm compared to more than 7cfm with most. You can swap out or buy with the larger SL60 torch if you desire. Around $800.00 with a buch of stuff with it including 4 year bumper to bumber warranty.
/ Plasma cutter question? #14
100 amps really is a beast. I used to have a TD 152. 120a. Very Messy.
/ Plasma cutter question? #15
Same here... love my 45XP but my first cutter too. I was originally thinking of getting the 30XP for the 110v ability but then thought for future growth (hopefully adding a plasma CNC cutting table), I should go with the bigger unit.
/ Plasma cutter question? #16
Yeah, I think the 45XP will do down as the best unit ever built. I considered one but I got a 45 when they 1st came out and it blew up 2 months past warranty. Hypertherm would not help so I ditched the brand. Had I bought a different brand it would have been covered completly. That's just my sour grapes on Hypertherm. The 45XP is much more refined and really has no competitors. Great Kw's compared to others.
/ Plasma cutter question? #17
Really? I'm looking for a PC as well that matches the OP's needs. For an occasional use machine that can cut 28 gauge, most of the advise is to purchase a pro grade, daily use machine.
There has to be something out there that doesn't cost $$$$. Having a tool that costs what's been advised set gathering dust between small project uses is just plain bad advice.
/ Plasma cutter question? #18
I've had my Miller 625 for over 10 years and still love it!
Pics were cutting 3/4" , it was over it's rating and very slow but it cut it.
My O/A torch is for heating only now.
/ Plasma cutter question? #19
Yeah that is the dilemma on buying quality at higher dollars and being able to grow with it. It is only occasional use now but once I retire I plan to use it a fair amount more on bigger projects and ones that might actually make me some money. I also know I don't want to be buying a replacement especially when my income is fixed.
On the other hand, one does need to be realistic regarding the use he will get out of it. Doing the math, I probably shouldn't have spent as much as I did but don't regret it.
/ Plasma cutter question? #20
Yes, you had a plan and knew your uses and future uses up front before purchase. Good planning on your part!
Someone looking for a lower cost, low usage machine probably has no foreseeable plan like me. Just something better than a grinder with a cut off wheel.
2017 BOBCAT E50 EXCAVATOR (A65056)
2017 BOBCAT E50...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
T/A Dovetail Flatbed Equipment Trailer (A66736)
T/A Dovetail...
Iranch High-End Tricycle (A64119)
Iranch High-End...
2014 International 4300 DuraStar Crew Cab Knapheide Utility Flatbed Truck (A68183)
2014 International...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
