Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!!
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #1
BX23S-1
No Clue
Kubota BX23S
Guys & Gals,
Kubota has a recall for the BX series tractors... (i dont know who`s effected by this recall..???)
The radiator reservoir cap is plugged with plastic debris from the molding process. (pieces of the plastic molding are still inside the hole...!)
The problem continues... Kubota sent me a newly revised one, turns out the new one was worse than the original one on my BX23s. (i had already previously fixed my original one before the new re-vised cap arrived)
I have called Kubota about it, they are aware of it now after i told them about the faulty cap they sent me... the girl was very surprised BUT very helpful on the phone. I`m not going to worry about it, Kubota will make this right.
BUT.... in the mean time, if any of you folks got the new re-vised cap in the mail, MAKE SURE you check the hole to make sure its cleaned out and 100% cleared BEFORE you install it...!!!
If you do not make sure its clear, you CAN have overheating issues, and possibly toast your engine...!!!
If you haven`t gotten a new re-vised recall cap from Kubota, you can run a drill bit down into the coolant passage hole in the original cap and remove any excess plastic slag/material, it will work just fine after that.
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #2
Consumer Contact:
Kubota Tractor Corp. toll-free at 888-458-2682 (888-4KUBOTA) from 8 a.m. and 5 p.m. CT, Monday through Friday or online at www.kubotausa.com and click on Service & Support then Safety, then Safety Notices for more information.
Recall Details
Description:
This recall involves model year 2014 to 2018 Kubota with model numbers BX, GR, ZD and ZG, diesel and gasoline-powered zero turn mowers, compact tractors, and ride-on mowers. The model number is printed on the side of the unit. Kubota is printed on the side of the mowers and tractors. The data plate has the serial number and is also located on the side of the unit. Recalled units are orange and black.
List of models, years and affected serial numbers here:
Kubota Recalls Mowers and Compact Tractors Due to Burn Hazard (Recall Alert) | CPSC.gov
Consumer Contact:
Recall Details
Description:
DIGGIN, THANK YOU sooooo much for posting that info, i could not find it earlier but wanted to get this notice out to ya`ll when they sent me a bad revised/recall cap...!!!!
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #4
I don't understand... why didn't they just put an overflow on the coolant bottle itself, instead of integrating it into the cap?
I've always wondered that on my BX.
My thoughts too!!! But the biggest problem is the cap itself... the nipple has plastic debris stuck in the hole from the process of how they`re made.
They wern`t deburring the cap and just shipping them regardless. Quality control should have NOT missed this, especially when they sent me a bad revised/recall cap!!!
My original cap wasn`t near as bad as the one they sent me for the recalled replacement!!! Like i said, its a quality issue. Somebody`s sleepin on the job!!!
I`m going to modify my tractor to have a normal recovery tank with a over flow hose routed to the underside of the tractor frame.
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #6
Well, I find this rather ridiculous! Embarrassing to say the least. I got my new cap in the mail last week, but didn't even look at it, because the cap on my tractor was fine. I'll have to take a closer look now. :shocked:
Looks like K-Corp needs to do a little house cleaning....
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #7
This entire scenario makes even less sense when you consider - the cooling system on my 2009 Kubota M6040 DOES have an overflow and drop pipe on the coolant tank.
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #8
THAT would cost a few cents more to make, so it makes perfect sense.. also, cutting down quality control saves a few cents, if they can get away with it..
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #9
Now look at how much it's costing them... not good.
All this gets passed to the next generation of buyers. People like me who will be buying a new machine a few years down the line.
Thats how they should ALL be made, with a drop tube!!! My tractor will have a new tank with a drop tube very quickly. Already found the one i want to use.
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A55973)
Paladin 12in...
INOP/NON-RUNNING 1999 Isuzu NPR-HD Cab and Chassis Truck, VIN # 4KLC4B1R5XJ001370 (A57453)
INOP/NON-RUNNING...
Cat 936 936F 938G Forks (A59213)
Cat 936 936F 938G...
2014 MACK CHU613 FRAME (INOPERABLE) (A58214)
2014 MACK CHU613...
SCREENER (A58216)
SCREENER (A58216)
