Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,441
Here is a video of my Furguson TO35 Plowing a heavy wet snow with a 6' Fisher Plow on a custom mount I built... Engine mounted the Fisher Truck Hydraulic Pump to run the plow independent of the Tractor hydraulics....
Did a complete engine overhaul since this video.
Furguson TO35 With 6ft. Fisher Snow Plowing - YouTube
Do you have any pics of your Ferguson? I’d LOVE to see them! (If not here, in this thread: https://www.tractorbynet.com/forums...ge/382043-massey-ferguson-picture-thread.html )
   / Pictures of your snow weapons #4,442
Re: Pictures of your snow weapons. New Front Chains and Bought another set
New Front Chains plus I bought another set. I snapped up the latest chains n Amazon. A warehouse special deal.
I Just put a cheap set of Chinese knock offs on the tractor. They should last 3-4 good storms.
The new chains are supposedly manganese alloy steel. We will see if they stand up better.
https://www.amazon.com/gp/product/B0091RCIR6/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Another year, another few pounds of weld metal in the old plow.
These look mean and expensive!
Aquiline Tire Chains
Update 11-20-18:
We got + 6" of snow as we are at 1,000 ft. Elev.
My sweetie has the week off, so she did 2 hours of plowing. I came home from work and plowed for another 2-1/2 hours.
It is going to get cold and the wet snow would to to ice chunk, so I cleaned up well.
I plow too much area.
Area between house and equipment building is 85' x 200' =17,000 ft^2 (Miserable without a snow pusher or Blower.)
Along side house and garage is 40' x 150' =6000 ft^2. ft^2 (A snow pusher would be good for part of this, plow for remainder.)
Back of house and kennel area is 2000 ft^2 (Good plow work)
Area by lean-to is about 1,500 ft^2 (Good snow pusher work)
Road around barn & up to Manure Pile is 300' X 12' = 3,600 ft^2 (Good plow work)
Turn around area at Barn is about 1,600 ft^2 (A snow pusher would be good for part of this, plow for remainder.)
driveway is 1200' x 12' =24,000 ft^2 (Fairly easy plowing with the old Fisher, Good plow work)
Total of 55,700 ft^2, more than an acre!
I wish I had a snow pusher, better yet two good size cabbed tractors one with snow pusher on front, blower on rear.
Then I wish my L39 would grow into an M59 with cab & a 9' V plow.
  • Peerless 0155305 Auto-Trac Tire Traction Chains, Wharehouse  Amazon Deal.JPG
   / Pictures of your snow weapons #4,443
   / Pictures of your snow weapons #4,444
   / Pictures of your snow weapons #4,445
Just finished oiling the tractor the other day with both Carwell and Fluid Film. I have the new snow pusher (w/back drag) on as the new snow weapon for this year along with the snowblower.
   / Pictures of your snow weapons #4,446
That 860 4WD is cool! Used to have a '58 600 on the farm, loved that machine....simple, and stone reliable. Do I also see the nose of a Shelby behind the KB???
860 with 4wd is a very rare Sherman Napco conversion. Very few of them in existance. I also have a Ford 841 with the Elenco 4wd conversion that is a major project. Here are the two old 4wd tractors side by side.20180929_161613.jpg
Sharp eyes on spotting the Shelby clone behind the Kubota. Here is a better view.20180929_140305.jpg
   / Pictures of your snow weapons #4,447
860 with 4wd is a very rare Sherman Napco conversion. Very few of them in existance. I also have a Ford 841 with the Elenco 4wd conversion that is a major project. Here are the two old 4wd tractors side by side.View attachment 579993
That sure looks like a Dana differential. It would be neat to see a description/pictures of how that conversion was accomplished.
   / Pictures of your snow weapons #4,448
I have copies of brochures of the conversion that show where the chain drive for the front axle gets it power. The front axle is a closed knuckle Dana.
ShermanNapcoAddProgressiveFarmerDec1958.jpgShermanNapcobrochure2.jpgShermanNapcobrochure4.jpg
I found a picture of the 860 with the rear snowblower I used for a few years.1955 860 2.JPG
   / Pictures of your snow weapons #4,449
Blades are now on both the JD 40S & the 2418 Power King: Tractors 2017 160.JPG
   / Pictures of your snow weapons #4,450
Doing an up grade to a 9'6" Fisher XV2 blade. I'm getting it put together right now.
So far this is all I have for pics.
The blade is together in the shop and I'm making the "hitch" for the tractor and some rigid stops so that the angle cylinders are not supporting the pushing load while retracted. For some reason this is an option of $220! The old blade I've been running has been worked hard and is "tweeked" pretty badly, still works but it's time.
Here's the old plow.
The frame broke in half a year or 2 ago and that was a just a welding job mostly, now the moldboard's have a twist to them and it's getting tired.
Most of the welding is done and after some primer & paint I'll have some pics of the new blade.
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
(1) HD 25ft x 24ft Metal Building Frame (A57453)
(1) HD 25ft x 24ft...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2010 John Deere 8329R Tractor (A59814)
2010 John Deere...
