Draining coolant on mCRD engine?
/ Draining coolant on mCRD engine? #1
TractorNH
Southern NH
Mahindra 2655 HST Cab, Deere 350C Dozer, Case 580CK TLB
Does anyone know if there is a coolant drain plug on the engine block on the mCRD engines or will all of the coolant actuallty drain out using the radiator drain plug? Asking in reference to the 55hp engine but guessing they are the same across several HP engines.
/ Draining coolant on mCRD engine? #2
don't know your engine but disconnecting the lower radiator hose on what I've seen usually lets all engine coolant out.
I'm not sure if it would since it looks like the block heater and freeze plugs are lower than the height of the water pump so not sure how much coolant would remain in the engine. Also not sure how low the cylinder walls go and since it's a wet-sleeve engine the coolant surrounds those as well.
/ Draining coolant on mCRD engine? #4
The radiator drain plug is what it has. To get the remaining coolant the manual recommends you “Install a good type of radiator cleaner” and “Follow the instructions given with the radiator cleaner.”
Then “Remove the radiator cleaner solution. Flush the system with clean water”
Finally install good ethylene glycol coolant.
The same thing happens with your hydraulic system. The design is to get most of it. But you will leave a good portion.
1999 Ford F-150 4x4 Pickup Truck (A61568)
1999 Ford F-150...
2012 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A61568)
2012 Chevrolet...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2019 FORD F-250 (A60736)
2019 FORD F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
