Kubota B1750, in need of some Turf tires
   / Kubota B1750, in need of some Turf tires #1
Wasmeneh
I really would like to find some turf tires, which as I understand it, also would recall some new wheels. The current tires are ags which are ruining the yard which is normally wet. The current rears are 9.5 ×16 and fronts are 6×12. Anybody have any ideas where to look for some?
Thanks,
Mike
   / Kubota B1750, in need of some Turf tires #2
Thanks,
Mike
I have a B1750HSDT bought new in 1993. It has turf tires on the front and compatible "bar" (not R-1 or R-4) tires on the rear and has had since new.
Finding a set of used tires and rims may take some doing but new ones should be available from Kubota or a decent AG tire shop. Yes, they will be expensive.
The OEM factory turf tire sizes (FWD) are: Front, 20.5x8.00-10; Rear, 29x12.00-15 (or Rear Bar, 31x13.5-15).
SDT
Well I called my closest full service Kubota dealer about Tires for my b1750d. After a couple of days they called me back and advised that the required wheels were NLA.
They advised me to call a tire shop and see if they could work anything out with current rims. I called and the owner advises he would get back to me in 30 minutes. That was 36 hours ago. Any ideas?
   / Kubota B1750, in need of some Turf tires #4
I really would like to find some turf tires, which as I understand it, also would require new wheels.
True.
Once you decide on size of Turf Tires and rims you want, eBay is a great place to shop. I recently shopped for a replacement Turf Tire for my Kubota RTV500 utility vehicle: Dealer $208 + sales tax = $220. Same tire, eBay, $144 delivered, no sales tax.
FRONT WHEELS & TIRES: tractor tires 20.5 X 8. X 10 | eBay
REAR TIRES: tractor tires 29 X 12. X 15 | eBay
   / Kubota B1750, in need of some Turf tires #5
There is nothing special about the rims. They are just Japanese truck rims.
Though they may no longer be available from Kubota, they will be available from other sources.
Dean
Thanks for the information, didn't know they were truck rims. Checked EBay nothing, any other places?
   / Kubota B1750, in need of some Turf tires #7
TIRES + TIRES ON RIMS: tire 31 X 13.5 - 15 | eBay
WASMENAH: Not much initiative on your end.
Can find tires, no problem, wheels are the issue.
Found front wheels on eBay, still looking for 15" rims that will accommodate a 29 x 12 tire. Any ideas?
Bit the bullet and found some on EBay from Or. They are on the way, shipping was outrageous.
2008 International 7500 Altec A77-TE93 92ft. Material Handling T/A Bucket Truck (A55973)
2008 International...
PORTABLE AIR COMPRESSOR W/ GAS MOTOR (A58374)
PORTABLE AIR...
John Deere 4600 (A53317)
John Deere 4600...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
