BX 2380 hard to start less than 100 hours
   / BX 2380 hard to start less than 100 hours #11
Every diesel has fuel injectors. I think this is a job for the dealer, in spite of the wait. Having said that, being told you have to wait 2-3 weeks for warranty work is poor service.
   / BX 2380 hard to start less than 100 hours #12
How long are you letting the glow plugs stay on before you start? Does it make a difference if you hold them for 4-6 seconds vs 1-2? Sure seems like a glow plug issue.
   / BX 2380 hard to start less than 100 hours #13
Whats your outside temp? If its cold out mine won't start very well without using the glow plugs. I try and start mine at about 1/4 throttle. If it runs fine once started I'd also say glow plugs, relay, wiring, something like that.
A long time, up to 10 seconds and doesn't make a difference. When new I let them heat for 4-5 seconds and it started no problem.
It started having this problem late summer when it was in the 70's-80's.
I'm suspecting the fuel pump now, fuel pressure to be specific.
   / BX 2380 hard to start less than 100 hours #18
Do you guys get that biodiesel crap out there?
   / BX 2380 hard to start less than 100 hours #19
Something is wrong. When it’s warmer out I still glow plug mine for just a few seconds but do not have to. I get people wondering about fuel quality but normally you would have problems with the tractor not running right under load.
   / BX 2380 hard to start less than 100 hours #20
Can you hear the fuel pump when you turn the key on...? Pressure & flow tested..??? Pinched fuel hose somewhere...???
How about the fuel cut off solenoid (attached to the injection pump), is it sticking closed briefly, or stuck partially closed...???
I dunno, i`m not there to see whats actually going on, just throwing some ideas out there.
2016 PETERBILT 389 FLATTOP (A58214)
2016 PETERBILT 389...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A58375)
2013 CHEVROLET...
New/Unused Forklift Jib (A57453)
New/Unused...
