   / Harbor Freight Tools that don't suck #10,261
The recoil doesn't bother me (yet), but E/S is nice as long as it doesn't eat the battery too often.. Those small batteries can get pricey,
I'm just not sure about the extra $300+ for the extra 1500 rating. Since I have the 8250 to run lights and motors, I'm not sure I need the 3500 if the 2K will run my electronics.
   / Harbor Freight Tools that don't suck #10,262
When I got the gen it didn't bother me either, I wanted it so my wife could fire it up if needed. I wrote out directions on how to set the whole thing up. My shoulder has been bugging me for a while so now I'm happy I have it because it takes a bit to start after sitting. My FIL's 2k Honda is much easier to start so maybe the smaller unit you are looking at would be too. As for the battery, if needed I use my jump pack to get it going but I have yet to replace the battery.
   / Harbor Freight Tools that don't suck #10,263
Many pages back I wrote about the HF Angle Grinder Holder that makes the grinder into a cutoff tool. It was unsatisfactory. The lightweight sheet metal base flexed too easily letting the cutting disc wander. This was unsafe in addition to making an inaccurate cut, a thin cutoff disc can shatter if flexed sideways under load.
Today the equivalent tool but with a cast iron baseplate is in a Northern Tool email ad. $15. I bought it.
I was asked to report on this Northern Tool Angle Grinder Holder after I got it set up:
I like it. It's solid, precise, just what I need. It's a valuable addition to my tools.
I mounted an old $10 HF DrillMaster angle grinder (4.2 amps) in it. That has plenty of power for driving the thin cutoff blade. It continues to cut precisely when weight is applied to work the grinder harder. It simply works. It's better than I expected.
If you buy one: Setting it up precisely is like the many adjustments you do to make a table saw cut true - adjust, measure, adjust some more, repeat. After considerable tinkering, it makes cuts that are as true as I can evaluate by comparing a finished item to a carpenter's square.
My cheap DrillMaster angle grinder isn't as fat as this was designed for. So that meant more tinkering to get the cut moved over, to not nick the vise and baseplate. I notched the washers that mount the superstructure to the base, to get the Allen screws even closer to the upright part. See the photo below.
The manual says it's for 4.5" and 5" angle grinders. My grinder is 4.5" but I have a 10-pack of 4 inch cutting discs. They are too small. After their diameter is ground down 1/8" smaller they wont reach the bottom of a cut. This needs 4.5" cutting discs.
I can't think of anything else. In summary -just buy it.
   / Harbor Freight Tools that don't suck #10,264
While on the subject of gen sets.. on ebay theres a DuroMax 10K watt duel fuel, that goes on sale periodicaly.. its 999.00 NOW but it goes up & down dramatically.. I got mine for 499.00 w/ free freight shipping.. The last sale I saw was 549.99.. comes w/ electric start & a battery AND the hose to hook-up propane..
   / Harbor Freight Tools that don't suck #10,265
^^ But that's not an inverter type. That's a conventional unit and the output can be 'dirty' causing performance issues for electronics. That's what's happening with my 8250 and why I need something else.
It was suggested that using a device to create additional load would help and I found that running a window A/C in summer or inductive heater in winter helped a lot to smooth the output. But that also caused more fuel consumption which reduced run time. That may not be an issue for short term outages, but can be a big problem for a ten day outage where the roads aren't passable. I try to keep at least 20 gallons of gasoline on hand, but the 8250 only gets about 8 hours on 6 gallons, so I could burn that 20 gallons in about a day. At $2 or more a gallon, that can get expensive right quick. With the gas stations gouging us during 'peak demand' times like outages, gas could easily go over $4/gallon.
   / Harbor Freight Tools that don't suck #10,266
I have an older Generac with a Honda engine. It starts easy enough but at 4200 watts it doesn't like to start my 1 1/2" well pump. Being a regular Honda GX engine it's also pretty loud. Two of the 3500w inverters would be enough for me but that's two engines vs one to maintain. It would be nice to be able to run just one most of the time and fire up the second when needed. The other option would be to mate a 3500 and a 2000 together. That would give me a nice lightweight quiet portable generator and a little more to handle the well pump. It's a shame that a stand alone diesel gen is so expensive. I've always got diesel on hand.
   / Harbor Freight Tools that don't suck #10,267
But honestly, i have a mental problem that tells me that i must stock many of everything. I can't buy less than 3 of an item that is a consumable. Sometimes 6. I can't control it. I'd the stores run out of what you need during the zombie apocalypse, it's okay. I've likely got 10.View attachment 576559View attachment 576560View attachment 576561View attachment 576562View attachment 576563View attachment 576564
I don稚 consider it a problem.
I don稚 pay the raised price that automatically comes with having to buy some of this or that because I ran out.
Just take a look at the inflation on the price of oil! I might not have to buy any for the rest of my life because I once got a reall good deal and brought a truckload home.
WD-40, I,m still using it at 1990痴 prices
The trick is to buy the hints you will actually use in multiples and try to force yourself to only get one of those that you will most likely use once or twice in your life.
   / Harbor Freight Tools that don't suck #10,268
I'm not seeing any reason for a professional mechanic to do it either. Smart, to me, would be using that extra $3 to $4K to buy tools. Or the family something nice.
Have to agree! Also have many friends who worked thier entire life as mechanics and also agree.
   / Harbor Freight Tools that don't suck #10,269
Yes, I've one and try to post every time the price drops down into the $600 or less realm, but sometimes that only lasts an hour or so.
   / Harbor Freight Tools that don't suck #10,271
I put solid tires on my pellet grill. Tired of Chinese flat tires.
Did same to garden hose cart.
There should be a Full thread started on "Tired of Chinese flat tires." I know I have multiples. Dolly, 25 gallon liquid sprayer tank trailer....
Also, Chinese inner tubes are mostly crap. If anyone knows a good brand of Chinese inner tubes, let me know please.
   / Harbor Freight Tools that don't suck #10,274
^^^ Original full price only, I would imagine.
The 3500 Inverter generator comes to $653. Lowest price I've seen before was $679 or so.
The 2000 comes to $425 which I've seen in that area before.
   / Harbor Freight Tools that don't suck #10,275
Yesterday's HF visit... A mini impact driver. I'm shocked and amazed, I over tightened an intake bolt and snapped the bolt with this little thing, and I removed the lug nuts, removed engine mount bolts and really surprised myself 50 times over as I used this and changed the upper and lower intake gaskets on my 04 Grand Prix 3800. I paid $100 with the super coupon.
The pliers sorters were American made from Amazon at $11 each.
20181118_154238.jpeg20181117_185832.jpeg20181118_154841.jpeg20181118_080811.jpeg20181118_154329.jpeg
   / Harbor Freight Tools that don't suck #10,276
Four day 15% off sale on many previously excluded items.
I wonder if it includes Lynx batteries? Might be a good time to pick up a spare.
   / Harbor Freight Tools that don't suck #10,277
Coupon Code 49491843
ALL LYNXX ITEMS
That sure sounds to me like all Lynxx branded items... So why is it not working on the website? I think that I would go politely argue that one with the local store manager. That's pretty crappy, saying "all exclusions removed" and saying all Lynxx stuff.... And then excluding the Lynxx batteries.
Yep, I'd be trying to sweet talk the store manager.
   / Harbor Freight Tools that don't suck #10,278
View attachment 579489View attachment 579490View attachment 579491View attachment 579492View attachment 579493
So you're liking the Hercules battery tools !? Kinda had my eye on them. They look nice and don't seem to be overly priced..
   / Harbor Freight Tools that don't suck #10,279
Here is the deal.... It works great. For now. It may work great for 2 years or maybe 10 years. But I'm not a "repair my electric tools" kind of guy. So for me, knowing that there is really no path to repair or replacement parts is not a big deal. I did pay the $18 for the 2 year warranty, after that is up, if it breaks I'll go buy another tool.
Some guys will fix up broken electric tools and as many years of service life. For them buying a DeWalt or a more reputable brand that has a clear path to repair parts really has value.
So who are you? Do you want repair parts or do you throw it away and buy new?
Oh, the mini impact is way above what I expected. I'm really impressed at the 18 hours of ownership level.
This is my first non DeWalt battery tool, so I think I'm going to commit to Hercules and get a few more, similar to my commitment to Lynxx.
2007 Ford E350 (A55973)
2007 Ford E350...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A59230)
Pallet of...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 CATERPILLAR 257B3 SKID STEER (A60429)
2012 CATERPILLAR...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
