BX23s Front Loader - I need the Female side of the Hydraulic Quick Connect Assembly
   / BX23s Front Loader - I need the Female side of the Hydraulic Quick Connect Assembly #1
BX23S-1
No Clue
Kubota BX23S
I`m looking for a complete replacement Hydraulic Quick Connect Assembly (female end that comes off the tractor for the front bucket loader) on my 2017 BX23s tractor.
I am attaching a blade on my tractor, so i need that whole complete female flat face assembly (stays on the front loader when removing it) so that i can hook up and run my dozer blade.
Does anybody know the part number and the price of the 4-valve flat face female assembly that comes with the bucket loader for the BX23s...????
Thanks guys
   / BX23s Front Loader - I need the Female side of the Hydraulic Quick Connect Assembly #2
See attached screen shot...
   / BX23s Front Loader - I need the Female side of the Hydraulic Quick Connect Assembly #3
For future consideration, check out Messick’s parts website. They have amazing tools for finding these and very competitive prices. Looks like diesel85 has you taken care of.
Thank you diesel85,
i was actually coming in here this morning to let you all know i finally found the information myself.
Gets harder everyday to jump thru all the hoops to find things you need anymore.
Maybe i`m just getting to old... ;)
Thank you :)
That was the first place i looked because ya`ll honer messick`s like a god in here. I actually found the parts (alot easier) on the Kubota website. There were less hoops to jump thru on the K-website vs messick`s.
I know my dealer will sell it to me cheaper than messick`s will. I`ve tried to do business with messick`s in the past, my local dealer seems to beat messick`s prices, and always by quite a large margin.
Thanks anyways!
   / BX23s Front Loader - I need the Female side of the Hydraulic Quick Connect Assembly #6
Glad I was able to help. Did my good deed for the day. :)
   / BX23s Front Loader - I need the Female side of the Hydraulic Quick Connect Assembly #8
If your BX is like mine they are standard Parker fittings. Number should be stamped on the side. Probably half the price or less at a hydraulic shop.
Ron
Ron
Thanks Ron, unless you have a BX23s, that has the 4 fixed couplers built into a 4-inline aluminum manifold, its not like the older BX series, its something new that kubota did with the (2017) quick attach front loader.
I`ve tried single ones already, wont work in my application... i`m stuck buying the complete upper output coupler manifold. ($200) I had my doubts when i bought the BX23s just due to the 4 in-line hydro coupler.
As it is right now, if you blow one coupler, your on the hook to buy all 4. It comes as a kit. I`m already thinking about yankin the 4 in-line system off and just install separate couplers. Blow one, replace one.
   / BX23s Front Loader - I need the Female side of the Hydraulic Quick Connect Assembly #10
I knew that just forgot. I saw that arrangement on the sales lot and was not impressed. Looked like something destined to fail. Probably a big thing with today's technocrats. Just another OEM gimmick to increase parts sales cash flow? Your idea makes sense; I would change them all when the first one fails.
Ron
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2015 INTERNATIONAL DURASTAR 4300 (A58214)
2015 INTERNATIONAL...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
MILWAUKEE HAMMER DRILL & WHEEL PULLER SET (A58374)
MILWAUKEE HAMMER...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
(2) AIR OVER HYD JACKS (A58374)
(2) AIR OVER HYD...
