What the heck is making these holes?
   / What the heck is making these holes? #201
Make some little snares and put over the holes. use some fine copper wire.
   / What the heck is making these holes? #202
If it's an insect you're not going to find out until Spring. Probably the same if its a critter.
   / What the heck is making these holes? #204
Well, I was up again this weekend, with fresh snow, and no footprints anywhere outside the barn so…
You say that this floor is very old and somehow I got the impression that it was built with used lumber. How sure are you that these holes weren't there all the time? Maybe plugged with something that has fallen out?
   / What the heck is making these holes? #205
This is what most of us believe or have said from the beginning. But that theory spoils a lot of fun. :D
I don’t buy it. If plugs or whatever had simply fallen out, they would be laying on the ground underneath the holes, right? But I have looked and there is nothing there.
   / What the heck is making these holes? #207
I don稚 buy it. If plugs or whatever had simply fallen out, they would be laying on the ground underneath the holes, right? But I have looked and there is nothing there.
Yeah but if it was an animal or insect there would be without a doubt leavings of some sort. Also did anyone use a vacuum? If so the vacuum could have sucked up the plugs easily.
   / What the heck is making these holes? #208
Anybody close enough they can go with the OP so we can get another on-site opinion?
   / What the heck is making these holes? #209
Well, I was up again this weekend, with fresh snow, and no footprints anywhere outside the barn so?/QUOTE]
But, but... no flour dusting on the inside?
I just received my trail cam in the mail and plan to put it out today hopefully. See if I can start solving my hole mystery. James, if you don't mind, I will post results here. Maybe it will enticed you to do the same? :D
Don’t worry, Mark, flour this weekend. SWMBO is coming up. And you are welcome to drive up with your spy camera. Washington State is only a short drive away, after all.
2017 John Deere 5090GN (A53317)
2017 John Deere...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
43055 (A55851)
43055 (A55851)
White Metal Roof Panels (A55758)
White Metal Roof...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
