What the heck is making these holes?
   / What the heck is making these holes? #201
Make some little snares and put over the holes. use some fine copper wire.
   / What the heck is making these holes? #202
If it's an insect you're not going to find out until Spring. Probably the same if its a critter.
   / What the heck is making these holes? #204
Well, I was up again this weekend, with fresh snow, and no footprints anywhere outside the barn so…
You say that this floor is very old and somehow I got the impression that it was built with used lumber. How sure are you that these holes weren't there all the time? Maybe plugged with something that has fallen out?
   / What the heck is making these holes? #205
This is what most of us believe or have said from the beginning. But that theory spoils a lot of fun. :D
I don’t buy it. If plugs or whatever had simply fallen out, they would be laying on the ground underneath the holes, right? But I have looked and there is nothing there.
   / What the heck is making these holes? #207
I don稚 buy it. If plugs or whatever had simply fallen out, they would be laying on the ground underneath the holes, right? But I have looked and there is nothing there.
Yeah but if it was an animal or insect there would be without a doubt leavings of some sort. Also did anyone use a vacuum? If so the vacuum could have sucked up the plugs easily.
   / What the heck is making these holes? #208
Anybody close enough they can go with the OP so we can get another on-site opinion?
   / What the heck is making these holes? #209
Well, I was up again this weekend, with fresh snow, and no footprints anywhere outside the barn so?/QUOTE]
But, but... no flour dusting on the inside?
I just received my trail cam in the mail and plan to put it out today hopefully. See if I can start solving my hole mystery. James, if you don't mind, I will post results here. Maybe it will enticed you to do the same? :D
Don’t worry, Mark, flour this weekend. SWMBO is coming up. And you are welcome to drive up with your spy camera. Washington State is only a short drive away, after all.
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
2019 KENWORTH T800 KILL TRUCK (A58214)
2019 KENWORTH T800...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
