What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today?
'Maintenance Run' since it hasn't done anything else for a few days. Cranked it up and let it run at 1500 for a few minutes.
   / What did you do on or to your LS Tractor today? #222
it's rained so much here in NW GA where I am, I need to find floaties for it.....
I did get on it Saturday and work on the driveway some. I ordered gravel last week, but the guy who was 'supposed' to be bringing it has had nothing but excuses, I had no choice but to try to move some around and get out of the mud on the newest part of the driveway.
   / What did you do on or to your LS Tractor today? #223
It rained all day down here. I think thru Wensday
   / What did you do on or to your LS Tractor today? #224
yeah that's what they're saying for us too I do believe. I need to get out with the box blade while I can see where the water is pooling and cut some drainage to the ditches on the edge of the yard
   / What did you do on or to your LS Tractor today? #225
Good Idea. Mine is still down . Saturday we were ready to put it back together and could not get it in neutral. Pulled it back a part the shifter fork must have a special way it goes in. Everytime we put it in the flats on the rod were off. I asked my deaker in AL for that section of the manual.
The guys at Piedmont did not want to get the parts under warranty since they did not split it. They wanted 275 each way for transport
   / What did you do on or to your LS Tractor today? #226
wow, that's crazy. For the life of me I can't imagine why a dealer would or could, refuse to sell parts. You might want to look up an LS corporate number or two and give em a call
   / What did you do on or to your LS Tractor today? #227
They finally got them for me. I had to sign a statement they were not responisble duh. They are not use to a mechanic having a tractor. Use to users only. My dealer has no problem with it.
   / What did you do on or to your LS Tractor today? #228
Purchased some large shipping containers that were broken down. Dimensions are 21' x 8', built with 2x6's and covered with 3/4" exterior plywood.
Should be a decent start to a loafing shed for Mr. Fizz, the horse.
Unloading from my trailer in the picture.
   / What did you do on or to your LS Tractor today? #229
Worked on knocking down some old gopher mounds in two pastures, a couple of days ago.
With recent rains, pastures are now too squishy for tractor work so, planning on hooking up my rear grader to do some overdue ranch road and driveway maintenance.
   / What did you do on or to your LS Tractor today? #230
been needing some gravel on the driveway. Back in the spring, we extended the driveway all the way through from front of the property to the back. I had some gravel brought in, but it wasn't enough to be thick enough. With all the rain we've had the last few weeks, it had turned into a muddy mess. I put this thick, and it will pack and make a good base for some good gravel come spring. Man I love that free float setting on the loader bucket, sure does make smoothing it a lot easier
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
2022 John Deere 1025R (A53317)
2022 John Deere...
2012 Bigtex Trailer (A55973)
2012 Bigtex...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
