LED trailer lights
/ LED trailer lights #1
kingrace78
Prescott, Ks & Lee's Summit, Mo
AC D14, LS XR4046H
I am needing to replace the tail lights on my trailer. Are there any suggestions on which LED lights to buy or which ones to stay away from? The prices and reviews seem to vary quite a bit.
Thanks John
/ LED trailer lights #2
I've put Partsam LED tail and marker lights on three different campers, two utility trailers and two boat trailers - haven't had a problem with them yet and the first set I put on was over 4 years ago. They may be available from other sources, but I've always gotten mine through Amazon.
/ LED trailer lights #3
I replaced tail lights on one of my trailers with max haul 70205 from Amazon $22. Worked out fine.
/ LED trailer lights #6
Second vote for the Harbor Freight LED lights. Had them on my trailers for years without a single issue.
/ LED trailer lights #9
/ LED trailer lights #10
Another vote for the HF lights.
Those HF lights are over priced. Even with the occasional $29 coupon from HF, they are more expensive than other places for the same kits.
Did the price on those recently go up? That's the same kit I have, but I don't recall having paid anywhere close to $60 for them. Granted it was a couple years ago, but even without 20% off they were cheaper than anywhere else.
/ LED trailer lights #11
There was a recall of them a year or so ago. The claim was that some of them did not meet DOT standards. They may have redesigned them to meet current standards which could account for the higher price.
I don't know if mine were subject or not and didn't really care since they're on a utility trailer that doesn't get a lot of road use.
/ LED trailer lights #13
Almost all of my trailers have the same 4in recessed rubber mounted lights. I dont like the box syle trailer lighys. There to easy to break.
I bought all my trailers used and for the most part they needed to be completely re wired. I also have a mason dump that uses the same 4in rubber mounted lights.
/ LED trailer lights #14
I've had great success with the HF led taillight kit. Has held up the best so far on my dump trailer
/ LED trailer lights #15
FWIW, I found that if one needs replacing, the rest likely do. I searched around and compared prices for individual and sets. I bought something generic -- make sure the lights say DOT (though any fool can mark them as such). No preferences on my part.
Thanks everyone for their comments, I bought the Max Haul off of Amazon for $21.99. I was surprised at the quality of the wire and lights, very nice set, for the price.
John
/ LED trailer lights #17
I really like LED lights. Probably the only real bee atch about them is that they do not create enough heat [ waste heat ] to help remove snow or ice in the winter. That is why it is easier to rear end semi's in the winter snow storms.... You can buy Jeep LED headlights that have heaters built in to help keep them from caking with slush. :)
/ LED trailer lights #18
I have normal bulbs on my car and the heat from the lights dont melt the snow now get me rear ended.
I think your forgetting the huge vortex of air behind a semi. All that salt, road grime and water gets sucked to the back of the truck.
2001 TRANSCRAFT 48X102 FLAT BED TRAILER (A63569)
2001 TRANSCRAFT...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
Rhino SE8 Rotary Cutter (A64047)
Rhino SE8 Rotary...
