TD5030 Differentiall Lock Stuck On
   / TD5030 Differentiall Lock Stuck On #1
kf4uda
Middle TN
NH TD5030, 861 Ford Powermaster, CaseIH Farmall 35A, 555A Ford Backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800
I have a 2010 NH TD5030 4WD with the 12x12 mech shuttle shift transmission. The differential lock seems to be stuck on. It is harder to turn and leaves aggressive tracks. The pedal is not springing back up. Any ideas on what I should try?
   / TD5030 Differentiall Lock Stuck On #2
Crawl under it and put a bar or a long screwdriver under the mechanism that comes out of the transmission. It should be easy to pop up. Spray with wd40 and lossen it back up then apply oil.
   / TD5030 Differentiall Lock Stuck On #3
Drive straight and as you're moving, hit one of the brakes for either the left or right wheel.
   / TD5030 Differentiall Lock Stuck On #4
And/or back up and stomp the pedal a few times as you do. The 4wd on one of my tractors won't disengage unless I'm backing up, taking the pressure off the sliding sleve.
You need to get it to disengage as for a 3 wheeler ATV you can tilt to go around a corner.....I doubt you want to be doing that (if you could safely) with your tractor.
Thanks for your suggestions guys. I will give them a try.
   / TD5030 Differentiall Lock Stuck On #6
This ^^^ should work IF...it is in 2WD and you jack one rear wheel off the ground to relieve all pressure on the mechanism.
   / TD5030 Differentiall Lock Stuck On #7
My TD80D sticks sometimes. It's how I get it unlocked. You'd think with that big spring inside it would disengage by itself.
I really like my tractor but, if I farmed full time I'd be looking for another one. It's always something little going wrong. Like now I've got a seal on the lift arms leaking.
I think I just need to pull the arms off and push the shaft to one side to get to the seal. Is this correct? I'm assuming I need to drain all the hydraulic fluid also.
As usual thanks for your expertise RickB.
I tried all of the easy suggestions first without success. I finally got time to work on the tractor and did get get the lock disengaged by using a combination of DwaneB and RickB's methods. I rarely use the differential lock since the tractor is 4wd. Looks like I need to use it more often to keep it from freezing up. Thanks for all of your replies.
   / TD5030 Differentiall Lock Stuck On #9
I got a good deal on my TD80 and, it's a decent tractor but, I've had a lot of small issues with it. Water in the loader cables, fuel cable, e brake cable, pto cable, starter, fuel solenoid, fuel pump, sticky differential lock, and now the rear lift arm seals are leaking quite a bit. Some of it is cheap design but, mostly I think it's because the previous owner left it sitting outside. Hopefully it will do OK for me for the long haul.
   / TD5030 Differentiall Lock Stuck On #10
I see many shafts that enter the trans cases freeze up or turn hard from rust. They like to design these things with the oil seal on the inside vs the outside which allows rust to form between the shaft and bore. Get some good penetrating fluid and lube where the pivoting shafts go through any bushings or into the cases.
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
UNUSED LANDHERO LDH-830 WALK BEHIND POWER TROWEL (A57193)
UNUSED LANDHERO...
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
UNUSED FUTURE 16" AUGER (A57193)
UNUSED FUTURE 16"...
UNUSED FUTURE WS43 HYD WOOD SPLITTER (A57193)
UNUSED FUTURE WS43...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
