Grey Water Disposal
/ Grey Water Disposal #21
When I built my house I contracted to have a water softener put in. The same company had 2 different types of softeners. One had a scheduled regen every night, the other was a 2 tank on demand system (kinetico). I went with the kinetico and had a separate daylight drain put in just for the regens. I was told simply that there was no need to add extra water to the septic system. I wish that I would have just went ahead and plumbed in my kitchen and laundry room drains into it as well.
/ Grey Water Disposal #22
In many places, it's not legal to dump the laundry room to daylight anymore, as your underwear might have poop in it.
In our location, it was quite common to have the laundry just dump out in a rock field right outside of your house! The previous owner of our house was quite the do-it-yourselfer.... unfortunately. :laughing:
He remodeled the house and moved the bathroom to the other side and put the kitchen where the bathroom was. He piped the kitchen sink into the old septic system and installed a new septic system for the bathroom. Then he buried a couple barrels and an oval horse tank upside down and piped the washing machine into that. So there's three separate systems.
I found the horse tank when my tractor caved it in and my tire sank in the hole. It was dry as a bone. No wash water was getting to it. I found two more sinkholes where the barrels were burried, and replaced the barrels with plastic.
I found the kitchen system when the yard started sinking. I dug out the sinkhole and found a suitcase full of empty ketchup bottles, an old baby stroller, and various boxes of plastic jugs over the access hole to the tank. WHY??!! :laughing: The pipe between the septic tank and drywall had collapsed, causing the tank to overfill and plug up with kitchen waste. I ended up piping the kitchen over to the new septic system.
Then there's the "mystery pipe" that the basement wash sink drains into in the floor in the basement. He said it'll take 4 sink loads of water before it backs up, then you have to wait a day.... again, WHY??!! :laughing: No one knows where it goes. Fortunately, we don't use that sink very often at all. Maybe 5 times in the last 20 years. But WHY??!! do people do these things. :confused3: :laughing:
/ Grey Water Disposal #23
I had a flip house that had a washing machine in the basement and the basement was lower than the septic tank. So that’s one reason to do it.
/ Grey Water Disposal #24
I have put the washing machine waste out a hill side for years and have a buried stone pit for the softener discharge. I understand, that stuff can destroy the steel reinforcing of the septic tank.
/ Grey Water Disposal #25
Can you find any documented cases of the steel reinforcing in a septic tank being destroyed by water softener discharge water?
/ Grey Water Disposal #26
I have never looked. Maybe, some years ago, I recall hearing a horror story. But, it kind of makes sense to me, that salt water would play havoc with the rebar, just like it does on bridges.
But also, what of the effects of the salt on the well-being of the beings that are supposed to live happily in the septic tank.
I just finished cleaning my Piro-Ceram Fireplace Glass in the kitchen sink with high strength Industrial cleaner (A job I always look forward to) and scoop that water out of the sink in a bucket to dispose of it outside. What a pain, but I don't want that chemical in the septic either.
/ Grey Water Disposal #27
I'm not going to post my jurisdiction, but I've read the regulations and know for a fact that grey water disposal anywhere other than a sewer or septic system is forbidden. As far as enforcement, it will only become an issue when the house is eventually sold, which, God willing, won't be until my wife and I are six feet under in our very own "zone of disposal." :p Even if we did find ourselves having to sell the house for some reason it would be easily put back to the way it was with a few fittings and some lengths of PVC. The County Health Department would be responsible for any type of enforcement, and the only way they find out about this type of stuff is when they are doing inspections for new installs or repairs, (not happening anytime even remotely soon) or when investigating complaints-Its not as if I'm looking to dump it onto my neighbor's lawn. I'm a 1/4 mile off of the road in the woods, so there is no one to see anything or to complain.
Interestingly, I just went back through my files and found the septic plan with our closing documents. In it, the engineer that designed the system specifically stated "Garbage disposals and water softening equipment shall NOT be discharged to this system." In doing a bit of research I found that I can buy a lint filter for the washing machine, which is my biggest worry (the system should be adequately sized to handle the water), but it sounds like I really need to get the water softener discharge out of there ASAP.
If it is forbidden why insist on doing it? Your septic will handle it fine. Please, respect your environment and mine...
/ Grey Water Disposal #28
When something sounds like it could be a problem 'in theory' but it doesn't actually show up as an issue you kind of have to go with the 'what actually happens' side of things. I posted above about my 14 year old home with a perfectly functioning septic system. I also grew up in a house built in the 50's (I lived there 1970-1989) that had a softener discharging into a septic system that was never an issue. In my almost 50 years I've never heard of water softeners wrecking septic systems. If you know of a bunch of cases where that has happened please share, but otherwise this seems to be a case of reality not matching theory. Sometimes life is too short to worry about all the possible things that could happen. :)
Rob
/ Grey Water Disposal #29
I did some googling and found no evidence that salt water will destroy a septic tank. I'm guessing in the absence of oxygen, it isn't an issue. Aside from that, basically everything isn't good for your septic system though, it seems. And as I suspected, many and probably most systems aren't doing what they were idealy designed to do.
/ Grey Water Disposal #30
The water softener in my house (existing system from when I purchased the house, built in 1980) ... The softener discharge is plumbed to my sump pump discharge pipe, which runs downhill, under ground, about 75 feet into the woods (on my property) where the pipe pops back up to the surface. Not sure why they chose that method, but hey, at least the salt discharge prevents any possibility of my sump pump output line freezing over LOL.
My septic tank is a hole different story. The line runs to my tank which is about 20 foot off the corner of the house, then from there flows about 200 ft downhill to a secondary tank which has a lift pump, which pumps it another 500 ft uphill to a front pasture where the septic field is.
Again, not exactly sure why they planned it that way. One guess is that the area around the house was completely covered with trees when I bought the place, and they were trying to hide the house in the woods. I have since cleared that area out so it's open, but maybe they didn't want the field near the house because of all the trees ?
/ Grey Water Disposal #31
Pretty much everything I read says the saltwater discharge won't hurt the bacteria and good stuff in the septic tank.
/ Grey Water Disposal #32
And what does it hurt?
/ Grey Water Disposal #33
/ Grey Water Disposal #34
Your wallet if you get caught, for one thing. ;)
Salt water discharged directly on the ground can cause a salt buildup in the soil. Since salt never evaporates, it just concentrates. Only way to get rid of it is to flush it out to somewhere else or remove the soil.
Gray water can contain feces. It's generally illegal to dump feces on the open ground.
Soaps and detergents dumped on the ground can and will get run off into waterways.
There's all kinds of reasons not to do it.
/ Grey Water Disposal #35
Not playing Devils Advocate on Grey Water but I do live in a very highly regulated city in a highly regulated State and there is a permit process for residential Grey Water and have been to several homes that have them... with permits.
https://greywateraction.org/wp-cont...land-Graywater-Permit-Plan-and-Checklist-.pdf
You also live in a state with MASSIVE fresh wate issues. They can't afford to waste a drop.
Here, where I live, we are fortunate to have water pretty much everywhere underground. And, in some places, its very close to the surface. I think our well is something like 80' deep, our pump is about 40-50' down, but the water level is only about 20' down. Pretty much every drop of water we take out of the ground goes right back into the aquifer, with the exception of things like lawn irrigation, car washing, etc... which is subject to evaporation. One of the main problems we have around here is that poorly designed and poorly maintained septic systems easily contaminate the aquifer since it's so close to the surface.
/ Grey Water Disposal #36
Feces in gray water, give me a break. Like maybe as much as one squirrel crap? The soap is going to float to the top of the septic tank and is pretty much free to go out the fill lines. I’m not claiming dumping sewage on the ground is a good idea but it can’t be that big of a deal or farms and wildlife would have ruined the world by now.
/ Grey Water Disposal #39
Because moonshining is our birthright.
/ Grey Water Disposal #40
You are asking others here to help you break the law? Do you own an oil change franchise as well, and dump the used oil behind the building?
You did not post your jurisdiction but I'm glad you are not my neighbor ... such a thing would not be allowed anywhere near our horse estates.
Caterpillar 980F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 980F...
Caterpillar 615C Scraper Service and Parts Manuals (A63117)
Caterpillar 615C...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64279)
KNOW BEFORE YOU...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
