Kioti Lk3054 hydraulics quitting intermittently
   / Kioti Lk3054 hydraulics quitting intermittently #1
double hunter
Gold Member
Ford 1715
LK3054 hydraulics quitting,,I was pulling my finish mower today and after about 3 hrs the hydraulics quit, Fel, power steering and lift all quit,,turned it off and got off to check for leaks or any thing obvious,,nothing, cranked it back up and worked for a few minutes and could tell it was going to quit,,drove it to the house and let it set a while, not long enuff to cool off and and its working again,,its new to me, I just changed the fluid as I had to replace the pto shift fork,,dont know when the filter was last changed but am going to change it tomorrow if I can find one,,any other suggestions, anybody have a cross reference for the filter,,will try NAPA in the morning
   / Kioti Lk3054 hydraulics quitting intermittently #2
Changing the fluid and filter is a good idea. Even if it doesn't solve your issue, you will have a little more pease of mind.
Was it making any noise while trying to get it going? Also did the RPM have any affect?
   / Kioti Lk3054 hydraulics quitting intermittently #3
I would probably say broken pump drive gear or shaft. Would pull the pump to check both.
   / Kioti Lk3054 hydraulics quitting intermittently #4
Did the engin labour more than normal ? Check if the external controlevalve has a detent and if that lever was in working posision.
Like someone hang his foodparcel on that lever ?
does anybody have a cross reference for this filter
   / Kioti Lk3054 hydraulics quitting intermittently #7
Its metal mesh. Wash it out in kerosene
I pulled the filter off this morning and Ive never seen anything so bad,,about 1/2" La. gumbo mud settled in the bottom of the canister and the filter was horrible, drove 65 miles to my nearest dealer and they had one,,replaced it but have not had a chance to run it other than to just crank and check for leaks,,this should correct this
Tried the x-ref this morning and it only shows, air, fuel and oil
   / Kioti Lk3054 hydraulics quitting intermittently #10
Hopefully that solves the issue. I was afraid it was going to be a cracked pump. Kioti had 3 different pumps for the 3054 depending on year.
They started with a 8GPM pump and later replaced it with a 10GPM version. This version was aluminum and would crack with heat. Many of these pumps were replaced under warranty to a cast version of the 10GPM pump.
From what I see, this pump was a good one. In fact, I upgraded my pump to this version and so far it has been great!
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
