Regeneration cycle
/ Regeneration cycle #1
4merfarmer
Kubota B3350SU
My Kubota B3350SU seems to need to run this regeneration cycle for an extended length of time after only a short amount of use. Last time the cycle ran for more than 45 minutes after only about 14 hours of regular use. Thanks for any insight.
/ Regeneration cycle #2
45 mins sounds long. Are dash lights flashing or on steady? My L3301 takes around 10 mins to do regen. And requires that throttle be put around PTO speed. Mine has probably done 6 regens in 97 Hours.
/ Regeneration cycle #3
Same. 10 minutes of regen every dozen or 2 hours on my L4060. Often kicks when I'm mowing & I dont even notice it.
/ Regeneration cycle #4
Run your RPM's around 1800 to 2000 and the regen cycle will be farther apart. My L 3301 did the first one at 14 hrs and then around 17 hours after that. I have 600 hrs on mine and it does the regen between 20 and 30 hours. The harder you run the engine the farther apart they will be
/ Regeneration cycle #5
14-15 hours is about right but 45 minutes is much too long. Should take 15-20 minutes.
As previously mentioned keep engine speed above 1,800 RPM, more in cold weather.
SDT
Wow, thanks for all the input! My first experience with this site and I'm loving it. So now the truth comes out. I stopped the tractor without the regeneration finishing (I thought there was something wrong, it had been running so long). Now the engine light has come on and it is making a loud beep in warning. I would appreciate any thoughts.
/ Regeneration cycle #7
Read the PM warning level 3 in the following LINK which is from your operators manual
/ Regeneration cycle #8
Exhaust filters live on heat!!! The more idle or low load the more PM's. The length of time it takes to clean a dpf all depends on temps. Outside air, engine coolant, and inlet and outlet of the dpf. The harder you run it the cleaner it will be.
/ Regeneration cycle #9
You need to read your manual carefully.
/ Regeneration cycle #10
B3350's are notorious for needing a very long time to heat the DPF to regen. Mine takes forever and if its cold outside it never actually completes it.
Search the site, you will find a lot of discussion the B3350 and regen (you may not like what you find).
Welcome to the board!
RGAZ
/ Regeneration cycle #11
If your model tractor is anything like mine, if you are where you can run it at 3/4 throttle you will go a long time between regen cycles. In the spring I clean out a horse corral and haul the manure to my place which is about 3 miles away, I am pulling a 10 foot dump trailer loaded as high as I can get it and run the tractor 3/4 to all full throttle. My regen time goes up to almost 40 hours in between. First time it did that I thought it was broken but it finially did its thing. On mine the engine changes pitch and I check the lights on the dash. One problem I have is in bright light my glasses get dark and I cannot see the lights in the dash. I alsmost shut mine one once when the lights were on
/ Regeneration cycle #12
90% of the time in COLD weather, the reason a Regen won't complete is because the coolant temp is too low. I've had the completely block off the air flow to the radiator to get a machine to warm up enough to start a Regen. Doing that you need to watch the ECT but it's easy to do this if it is very cold outside.
/ Regeneration cycle #13
It isn't.
The engine in the 3350 is unique in that it is the only Kubota mechanically injected engine with DPF. The regen algorithm is completely different.
SDT
/ Regeneration cycle #14
It isn't.
SDT
So a L3301 or L3901 would be direct injection?
/ Regeneration cycle #15
Direct/indirect injection is an entirely different matter.
The small 4 cylinder engine used in the B3350 and some TOL zero turn mowers is mechanically injected.
Other currently produced Kubota diesel engines used in farm tractors are common rail.
Designing a nonsensical DPF system for a mechanically injected engine is an entirely different and more difficult engineering project than such for a common rail engine.
I expect that Kubota will eventually work this out in some fashion but it appears that they are not yet there.
I also expect that Kubota will either redesign the B3350 engine with a common rail system or replace (or discontinue) the engine.
Stay tuned.
SDT
Dean
/ Regeneration cycle #16
So......
"Regen is so we can have a cleaner environment." Also: "If you have regen run your engine at a high rpm where it will burn more fuel!!!" :mur:
(Now I know why VW cheated.)
/ Regeneration cycle #17
So......
Yes that is basically right. I run my engine at what I think is appropriate rpm for job. When the regen light comes on I crank up the rpm till system is happy and perform regen. After regen is done I ease throttle back to appropriate rpm. This all would be a pain in the rear with a gear drive tractor but with HST it’s not too bad.
/ Regeneration cycle #18
Stay tuned.
SDT
Dean
Common rail is what I meant. Yes sounds like Mechanical injection and dpf is a bad combo for sure.
/ Regeneration cycle #19
I have a gear drive tractor and it is no different than running normanly. Mine did one today and I just shifted to low range 4 gear and kept working. Depending on what I am doing I do not use low range but did so today because the ground was rough
/ Regeneration cycle #20
and it's very bad for your tractor.
HST pumps need to run at a proper speed, it also keeps the fluid cool. Running them at low rpm will overheat them, lower their life expectancy.
I was told run ALWAYS above 1800 rpm, which on my kioti ck35 is 540 "e" pto speed. I find that if I run with the revs at 2000-2200 the regens are spaced way farther apart.
First regen was 37 hours, second 35 hours later at 72 hours. I've run it at 2k and above since then and am at 134 hours (62 hours since last regen) and not had another regen. Regens last 10-15 minutes while i"m still working.
now that winter is upon us we'll see how this goes. When I use the tractor it will be for shorter periods, plus it's gonna be winter diesel or I may put in additives so that may change things, plus warm up will be much longer (already noticed that with temps in the upper 30s). So I'm expecting much more frequent regen cycles.
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61569)
2017 Load Trail...
(INOP) CUB CADET 1810 LAWNMOWER (A62131)
(INOP) CUB CADET...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL8DL188033 (A61165)
INOP/NON-RUNNING...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A61568)
2010 Workhorse...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A61165)
2021 Big Tex...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
