shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,490
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
I have been having problems using my back blade to grade my gravel drive. It is a bit of a roller coaster with dips every 10-15 yards or so. When I use the position control to raise the blade as I go up a dip, I leave ridges that look like washboards. When I go down a dip, I wind up leaving more material at the top of dip...making the dip worse. I was having a bit better luck with the York rake but that may be due to it flexing more...I don't know.
It got me thinking about using a chain to replace the top link to give me a degree of float. I assume by using a chain, when I go up a dip, the blade will not dig in as much as it is not held ridgidly in postion with a sollid top link....is that correct?
To address the blade lifting as I crest a dip, I am thinking about having having some slack in the chain when the blade is on level ground...thus the blade would not lift as high but follow the ground. In operation, I would note the setting on the postion control when the implement is level on flat ground, and set the implement to that position when grading.
Before I do somethiing stupid and hurt myself, or the machine, I would appreaciate any comments. First, is there a better way (note: I cannot afford a hydraulic top link). Is what I am proposing safe to do with a back blade and/or York rake? Do you think it might work?
My other thought is to add wheels behind the blade so it performs more like a grader. Something like this:
5' Grade Blade w/wheels for ATV | Agri Supply
Thanks in advance!
Thanks in advance!
