Checking charge pressure
/ Checking charge pressure #1
Steiner5
Member
Bobcat Toolcat
Does anyone know what size/type of fitting is required to connect to the charge pressure diagnostic ports on a B-series 5600?
Thanks...
/ Checking charge pressure #2
Thanks...
I believe they are 3/8. Flatface. Maybe easer to get a JIC flare adapter to screw in and connect to your gauge. I take it the dealer had bad news?
Actually I haven't had a chance to take it to the dealer yet. I just thought since I have several gauges I would see if I could connect to the diagnostic ports and compare the output pressures to what the manual says. The connectors appear to be a poppet style male connector. I measured the O.D. of the tip with calipers and the it measures .450". I have been trying to find something that shows the OD of the male tip to determine what common size they are but haven't found anything yet. The plan is to still take it to the dealer but thought having the ability to check these pressures in the future might come in handy.
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
44052 (A55852)
44052 (A55852)
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Ford F750 Bucket Truck (A60352)
2007 Ford F750...
