Wanted - 15 x 10 rims for Toolcat
   / Wanted - 15 x 10 rims for Toolcat #1
Steiner5
Member
Bobcat Toolcat
I'm betting this is probably also a long shot that anyone would have these rims and want to get rid of them but thought I would ask. My TC desperately needs tires and am thinking about upgrading to 29" tires. It looks as though the larger tires requires the 10" wide rim. Let me know if you have a set and want to get rid of them.
   / Wanted - 15 x 10 rims for Toolcat #2
What tires do you have now and are you going to turfs? Looking at the G series book, the R4 can be had in 27" and 29" versions and they both use the 15x8 wheel (6688856). The 29" turf tire is 2" wider than the R4's and needs the 15x10 wheel (6688857).
ruffdog.... I currently have 27" R4 tires. I want to go to R1 tires due to the muddy conditions this vehicle will be working in. The only R1 tires that I have found that are 29" in diameter are also 12.5" wide and require a 10" rim.
   / Wanted - 15 x 10 rims for Toolcat #4
I understand now...going to a tire like the ditch witch's have, maybe.
   / Wanted - 15 x 10 rims for Toolcat #5
Are your wheels the 6x5.5" (6x139.7mm)?
   / Wanted - 15 x 10 rims for Toolcat #6
I looked up some of the black truck wheels commonly sold (~$75) on the internet and the rated load is 1500lbs. That seems low for even a pickup.....
No, the bolt pattern is 6 on 6 which seems to be commonly used on commercial or trailer wheels. Bobcat wants $500 for a set of four. I was just looking to see if I could find something a little cheaper.
   / Wanted - 15 x 10 rims for Toolcat #8
Yes, mine is a B-series. Thanks for the link. I didn't see a reference in the link regarding C-series but someone did measure the D-series and it is the 6 on 5.5" BC. They must have changed either at the C-series or D-series. This has me wondering if Bobcat ever made 15 x 10 rims with a 6 on 6 bolt pattern. The 15 x 10 rims were not even offered for the B-series.
Well, I just checked Bobcat's catalog. It looks like the first time they offered the 15 x 10 rim was for the D-series which is the 6 on 5.5" BC. I guess I am going to have to rethink my tire plan.
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
197359 (A50458)
197359 (A50458)
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
Danhauser 3 pt Post Hole Digger (A50515)
Danhauser 3 pt...
