Front-End Loader Loaders that will fit a TC35DA
   / Loaders that will fit a TC35DA #1
frozentundra
NH TC35DA
Hello All,
I just picked up a New Holland TC35DA, it was used as a mowing tractor so it never had a FEL on it but I'd like to get one for it to maintain a small road. I know the 16LA and 17LA came on those tractors new, I got a quote for a Woods LC102 for almost $8k which is more than I'm able to spend. Anyone know what other used FEL's will bolt up to that tractor so I can keep my eyes open on the used market? I thought I read that a NH 250TL will fit as well but I haven't been able to confirm that.
Thanks for the help!
   / Loaders that will fit a TC35DA #3
I have seen the 250TL on a TC35 but I don't know if there was any extra parts needed to install it, it is heavier that 16 and 17LA..
Got it, thanks! I've only found a couple 16LA/17LA's around so I was hoping to find a decent substitute. I'll keep researching, thank you for the guidance!
   / Loaders that will fit a TC35DA #5
If the overall weight difference is within reason between the 16 17LA and the 250TL and the extra parts if any are needed aren't crazy money I would put the 250TL on AFTER I called a dealer to make sure everything will work as it should..
Yeah, I hate industries that you can't just buy direct the things you need. Laundromat equipment is the same way, it drives me nuts, I want to be able to just figure out what I need and order it to my door without having the price doubled every set of hands it goes through.
Awesome, I think that was the link I found awhile ago then couldn't find it again. According to that it should bolt right up it would seem. There are more 250TL's around than the older 16/17's so I'll probably look for one of those.
   / Loaders that will fit a TC35DA #9
It will more than likely bolt up without any added cost but that probably depends on the year of you're TC.. Looks like 2008 and up tractors, not sure about before that..
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
500BBL WHEELED...
Hydraulic spike driver (A56435)
Hydraulic spike...
