12V dry spreader on FEL, who's done it?
   / 12V dry spreader on FEL, who's done it? #1
dalola
Ohio
Kubota BX2380 w/FEL, Woods RM48, Yazoo/Kees Max2 ZTR
I think it would be handy to mount a 12V dry spreader on the FEL of my BX, mostly for yard fertilizing. I've looked into a few, thinking the ATV type would probably adapt the best to the FEL. The problem I'm finding it locating a reasonably priced spreader that has 12V gate control. Most of those are up near $1K. I found a few decent manual gate models around $300. A manual gate is doable for sure, but will take a bit more mechanical alterations.
Wondering if others have done this, what they used, ideas, what brands to avoid, etc...
   / 12V dry spreader on FEL, who's done it? #2
I sorta did the same thing but I made a frame for mine and mounted it on my 3pt hitch. I then installed a 12v linear actuator on the gate and installed a reversing switch for it. You could also put a heavy duty throttle/choke cable on it to control the gate.
   / 12V dry spreader on FEL, who's done it? #3
This is what I was going to suggest....
Dale
   / 12V dry spreader on FEL, who's done it? #4
Fertilizer is corrosive. I'd rather spread it behind my tractor than in front of it, everything else being even. Not to mention better stability & a stronger simpler axle to carry the weight.
I like the cable idea, hadn't thought of that. I would need to go about 8 feet, which would be much easier with a cable. Thanks for the suggestion! More research tomorrow....
   / 12V dry spreader on FEL, who's done it? #6
   / 12V dry spreader on FEL, who's done it? #7
It sounds like a neat project, but consider the dust from the fertilizer that you'll be driving through. It's not a lot of dust, but both you and your tractor will be breathing it more than if you were pulling a spreader. I like the idea of a cable to control the gate, even on a pull behind spreader.
Look here for some possible cable options...Maybe to get idea what is available...
California Push-Pull Inc. Cable Specialists Based in Chico, Ca.
Dale
Thanks for the link, Dale. Hoping I can find a generic part to keep cost down, as I'm sure the custom cables are more $$$. Found a 10' push/pull in McMaster-Carr for $27, that I think I can make work. Need to figure out which spreader to use first! Kind of leaning towards a Fimco, as I've had a Fimco 12V sprayer for 10+ years that's worked great, still works great. They have a new 12V dry spreader for ~$300.
Really, the only application I make is the late fall winterizer, which is a pretty clean granular. Plus, I think it's far enough out front and low enough on the FEL to not be much of an issue, barring windy days of course, which I would avoid. I just like the idea of having it in front of me, for ease of use.
   / 12V dry spreader on FEL, who's done it? #9
I noticed you're in Ohio. If you are close to Shelby, take a look at Glen's Surplus. They carry a LOT of throttle/choke/brake cables. (edit: I think I see the one you mentioned, and it looks like a perfect choice)
Another nice advantage of the FEL spreader is you can easily raise or lower the height to extend or reduce the coverage.
72'' power rake (A53421)
72'' power rake...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2007 Ford Focus Hatchback (A55853)
2007 Ford Focus...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
