LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 12,288
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Update...
Figured out that the Pin holds the cable adapter in place on the piston rod. I hate working on stuff like this without a repair manual... LOL... Will try putting everything together tomorrow. I've got good measurements of the threads so hope all goes well. I've spent a lot of hours on this only because of no documentation or how to do hints. Its really not that hard of a job but that said its not done and adjusted... I have to say my 4020R and BL25R loader doesn't require removing the hydraulic unit, It just takes removing a front panel and a floor panel. Its tight getting in to a couple screws and not a lot of wrench swing space but its doable. I started on the bottom cable because there's actually more room on the bottom one from under the tractor. Then the top one from under and above worked well. More tomorrow..
Thanks,
Ron
Morning;
I'm not sure that I'm following your description.
My 8050 with the BL50 loader may be different then yours but here goes;
at the valve end the small threaded end goes into a U shaped clevis and the small nut secures the clevis to the cable.
The clevis is attached to the valve spool by a small pin with a spring clip holding the pin.
The cable is secured to a plate by a pair of nuts which adjust the cable.
I can try and get a picture later if it sounds similar to yours.
Good luck getting it going.
With you and Cougsfan being old timers I can understand it being difficult to get under your tractor and work especially when the weather gets damp,
makes me glad to be younger :cool2: (I'm not 70 yet, only 67) :drink:
