What's your favorite tool for cutting net wrap.
   / What's your favorite tool for cutting net wrap. #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I've removed net wrap with everything from a box cutter to a machete. I've even ripped it off with my hands when the netting was fine enough. Every method has had advantages and disadvantages. I guess my two favorites are a smooth bladed pocket knife and a crow bar. The pocket knife dulls quickly and I carry a carbide sharpening steel with me. With the crow bar, I use the claws to rip off about five inches at a time till I'm across the bale.
If anybody has a better method, please tell about it.
   / What's your favorite tool for cutting net wrap. #2
That's all I've ever used is the knife blade on my Gerber multi-tool. Mind you, I'm only cutting a single round bale every 10-11 days.
How many bales are you opening that would dull a blade so quickly? Regular mesh? Silage Wrap?
I like to keep all of my blades sharp for whenever I need them, but only truly sharpen them all around twice a year... not only because a dull knife isn't a knife but it impresses other people when I hand them one of my knives and warn them that it IS sharp. I love the look on their face when they use a blade that really is sharp as to what they've 'put up with'.
   / What's your favorite tool for cutting net wrap. #3
Sheffield knife with replaceable utility knife blades. My go to pocket knife.
Wagtail,
I feed up to four bales at a time depending on many factors. I've used a utility knife blade in a pocket knife like RickB describes, too. They didn't stay sharp very long either.
   / What's your favorite tool for cutting net wrap. #5
I don't use bales and I'm not sure what kind of wrap you're talking about, but if you have an issue with blades dulling, would a ceramic blade help? I noticed HF has a ceramic blade utility knife for $10 or so.
   / What's your favorite tool for cutting net wrap. #6
I just unwind the wrap with the bale in the air on the spear.
   / What's your favorite tool for cutting net wrap. #7
Saw with the serrated blade on a multi-tool, several bales a day.
Some haylage bales with plastic as well as net wrap some dry with just the net wrap.
Using a squeeze grapple, just net wrap bring the bale to easy reach and saw down.
With plastic wrap set it down cut a circle out of the top slice and saw down.
   / What's your favorite tool for cutting net wrap. #8
Don't use your tiller, it won't cut it very well. I found that out tilling a new garden for a new customer in what turned out to be an old pasture/feedlot. I spent more time cutting net than I spent tilling.
   / What's your favorite tool for cutting net wrap. #9
I use a sheetrock knife with extra blades in the handle. As soon as it gets dull, I replace the blade. Easy Pleasy!!!
   / What's your favorite tool for cutting net wrap. #10
I don’t feed hay, but if a knife wasn’t working well I’d probably use my cordless grinder.
Kubota L3130 (A53317)
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
