jrsavoie
- Joined
- Jul 10, 2010
- Messages
- 526
- Location
- Clifton, Illinois
- Tractor
- 1975 Ford backhoe/loader 3 cylinder diesel, 2022 Kubota LX2610, 1963 John Deere 4010 diesel wide front, 1996 Toro 223D Groundsmaster, 1998 Toro Groundsmaster 325D 4x4 72" deck cab & snowblower
Weather and terrain has a lot to do with it. I知 running dual 4228 antennas stacked on a 50foot tower and pull 80 miles regularly but you need to consider your antenna height and elevation , the desired transmitter elevation and power, and obstacles in between. On good days I can pull stations 120 miles away. After the digital conversion some transmitters went to directional antennas that are now pointing the wrong way for me to get reliably.
If you keep your runs short and set it up right ganging antennas makes a huge improvement on signal strength.
I'd like to know more about ganging antennas. Previously I had the biggest antenna Winegard made. The last time it blew away Winegard and a couple others talked me into a smaller antenna. It didn't get as many channels as the big Winegard got with half the aerials blown off.
I haven't had a chance to go through this thread. Is there a high quality rotor to be bought anymore?
ganging antennas - Google Search
