Oil & Fuel Hydraulic oil leak from filler cap
   / Hydraulic oil leak from filler cap #1
Bob999
Eastern PA
PT 1845, Bobcat A300, JD Trail Gator
Hydraulic oil has started to leak from the filler cap when working on steep cross slopes with my 1845. Tank is not overfilled.
Anyone had this problem? If so, what was the solution?
   / Hydraulic oil leak from filler cap #2
I have had my gasket leak but I do not remember the cap leaking.
Paper towels?
   / Hydraulic oil leak from filler cap #3
You are probably over full. Can you take a picture of your dipstick? The other opttion is that your dipstick is just old and the cork is failing (mine did).
   / Hydraulic oil leak from filler cap #4
Are you sure it is the cap? Mine leaked but it was from the steel plate that is on top of the tank. I took it off and cleaned it and just use some blue gasket sealer and reattached it. I haven't had any problem since.
Thanks for the replies. The leak is definitely from the cap. The leak started months after the last addition of oil to the tank. The dipstick shows oil only at the bottom 1/4". The gasket is rubber, not cork, and I suppose it could no longer provide a satisfactory seal. So far I have been unable to find a proper sized gasket. Does any one have a source?
   / Hydraulic oil leak from filler cap #6
The reason I was asking about the dipstick photo was to make sure you had a "factory" version. Yup, 1/4" or so on the impossible to read dipstick is correct. Is it pouring out or is it just a drip? No source of gasket material but buying a new dipstick from Tazewell was pretty cheap.
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A60429)
YANMAR VIO35-5...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
