Deere 3038e won't start, just a click, but not the good click.
/ Deere 3038e won't start, just a click, but not the good click. #21
you can start this manually by disconnecting the spade terminal connector on the bottom of the start and touch the spade terminal on the starter with a jumper wire to the hot terminal behind the red protective cover on the starter wires
went out this morning and check the battery, it was at 12.08.. so I did what you suggested and jumped from the spade to the hot terminal and it cranks.
I assumed I could start the tractor this way but it wouldn't ever start. it just kept cranking. I tried turning the key at the same time and made sure all the safety switches were in the correct position. checked for fuel and there is fuel.
So I'm getting it to crank this way but now I'm lost even more lol.
metered the seat safety switch as well and it was open but when I turned the key i would get 12.[/QUOTE]
if it cranks and you had the key to run position and did not start then the the fuel shutoff is not opening to let the injector pump pump fuel or not getting fuel for some reason. I've never worked on this model so I don't know how the fuel shutoff works BUT the older JD tractors that I have has a 3 wire shutoff. wires are 1-pull in 2- hold in and 3 ground. Test the pull in and hold in wires to see if they are getting voltage.
If they are getting voltage and the shutoff does not click then the shutoff is bad. If one of them is not getting voltage then you can jump the one that is not getting voltage. The shutoff solenoid should give a fairly loud click when the key is turned to run when it energises.
If it energises and still does not get any fuel then there could be a problem with the injector pump (I just had to have a injector pump rebuild cause it had stuck in the closed position). I will look on JD Parts and see if yours has the 3 wire shutoff.
From JD Parts the fuel shutoff solenoid looks to be the same type as mine. It does not show the wires but I suspect it is the 3 wire.
If you could post a pic of the the fuel shutoff connector that would help me help you
could also be that one of the safety switches is stopping voltage from getting to the furl shutoff solenoid. You would have to follow the electrical diagram to see which switch is not passing voltage.
Jumping the solenoid will bypass all the safety switches
  • Good Post
Reactions: jyb
/ Deere 3038e won't start, just a click, but not the good click. #22
If you remove the shutoff solenoid then that puts the injector pump in the open position (run position) and should start as long as its getting fuel. The only way to shut it off if solenoid is removed is to stick your finger or short stick in the solenoid hole to push the lever to the closed position.
/ Deere 3038e won't start, just a click, but not the good click. #23
Read these two threads on another site about 3038E and the thermistor in the gauge cluster. It is responsible for pulling in and holding the fuel solenoid so it will run:
THREAD 1 ,
THREAD 2
I'm getting fuel, when I crack this bolt (see image) open fuel is being pumped freely when the key is turned on. I removed the fuel relay to see if it made a difference and it didn't. it is cranking like no fuel/fire though.
Back to my original problem, me jumping the starter gets it to crank, so what am i bypassing that could cause it not to crank with the key? On a car we would do this when the starter solenoid was bad but we would no this from the clicking noises..
THREAD 1 ,
THREAD 2[/QUOTE]
good gosh i hope its not this lol.. if im getting fuel pumping then it pretty much eliminates this issue tho right?
funny thing though about those threads, I bought this tractor new 10 years ago and it has sat outdoors its entire life, beat to death.. abused.. and only time i had an issue was running out of fuel and trying to figure out how to get the pump to get fuel bad to the carb lol.. finally figured out it was electric and i just have to crack open that plug and let the fuel pump click on until i see fuel. lol.
/ Deere 3038e won't start, just a click, but not the good click. #26
Sounds like the thermistor. Loosening that nut on the injection pump only proves that you're getting fuel up to that point (your lift pump is working properly). The fuel solenoid on the injection pump is still closed and preventing it from injecting any fuel into the cylinders.
/ Deere 3038e won't start, just a click, but not the good click. #27
most pumps have a manual kill linkage on them once you bypass the solenoid and it starts - I ran mine that way a while until I figured out where to get a solenoid for my pump on my perkins pump - also if the thermistor is bad up in the dash it could be contributing to other power getting to other places so I wouldn't sweat that part either
older pumps were manual for the most part as they didn't use a key for starting they used power for lights/starting/etc..... but you pulled a lever to kill it, only issue with that is, if you ever blow the seal in some pumps they will flood the crankcase with diesel - that's a crapper!!!!
just tested the three replays and all three are switching properly..
so me jumping the solenoid on the starter and it cranking is saying i need a new solenoid or could there be some other reason why it wont crank with the key but will crank with a jumper?
/ Deere 3038e won't start, just a click, but not the good click. #30
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
HYSTER 50 FORTIS STRAIGHT MAST FORKLIFT (A59823)
HYSTER 50 FORTIS...
30KW GENERATOR (A58214)
30KW GENERATOR...
John Deere HX20 (A60462)
John Deere HX20...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
