Home built 2x72 belt grinder
   / Home built 2x72 belt grinder #1
PHPaul
Downeast Maine
Kubota B2650 with cab, Pasquali 986
I realize this forum is intended primarily for tractor-related implements and attachments.
However, many/most of the projects here are built from steel and steel fabrication requires grinding so there IS a connection. :D
I had to buy a piece of 25mm shaft (McMaster-Carr), four 3x3.25 load rollers (Surplus Center) and six 47x25x12mm bearings (Amazon). Total cash outlay was $85, not counting an assortment of grinding belts. The rest was built from stuff I had laying around and the motor came from a freebie yard sale treadmill.
More pictures and a blow-by-blow description of the build here.
   / Home built 2x72 belt grinder #2
That looks very nice! I also built a 2x72 belt grinder from scrap, but I was at a different station in life and didn't have things just laying around to build it with. I also barely had any tools. So mine looks like a Bangladesh special. Here it is: Home Made 2"X72" Belt Grinder - YouTube
P.s. I still have that old piece of crap rolling around in my shop and I still use it from time to time. I can't believe it hasn't fallen apart.
   / Home built 2x72 belt grinder #4
Very cool!!!!!!
How critical in the speed control feature on your grinder?
I have a table saw motor that might work for Home built 2x72 belt grinder, but its only a single speed?
   / Home built 2x72 belt grinder #5
What is the use of something like this?
   / Home built 2x72 belt grinder #6
Nice job. Making knives? Those treadmill motors are ideal for variable speed on projects such as this.
Just wondering why the load wheels are so wide?
Supplements (and largely replaces) a bench grinder. Easier to change grits. Wider so easier to maintain bevel on long pieces. Hard platen behind belt so you can deal with narrow/pointy stuff without worrying about gouging the wheel and having to dress it. Platen and work table are adjustable if you need to maintain a particular angle.
Very cool!!!!!!
Primarily for convenience. Faster speeds for faster material removal, slower speeds with finer belts to avoid overheating the material and losing temper. There are plenty of single-speed examples out there tho.
BigBarn said:
Nice job Making knives? Those treadmill motors are ideal for variable speed on projects such as this.
No, not into knives. Yet...:) Do a fair bit of "yard art" so odd shapes are pretty common.
Used those rollers because they were cheap. $6.95 each from Surplus Center. Kits with Custom 2" rollers were approaching $100, plus bearings.
   / Home built 2x72 belt grinder #9
We had a 6" belt sander at work. It was invaluable for metal and wood work.
   / Home built 2x72 belt grinder #10
I have a 6” also. The OP’s has the advantage of sanding radiuses with the contact wheel.
Here are mine. I am unable to do “slack belt” sanding though. Probably build my own similar to the OP’s someday (maybe)
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
Ammco Brake Machine (A55758)
Ammco Brake...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
